Home > Technical (L322) > Rear suspension knocking |
jonminns Member Since: 07 Mar 2011 Location: Leicestershire, UK Posts: 155 |
Unsure to be honest, i have this issue on the drivers front so interested as to your progress 2008/58 FFRR 3.6 TDV8 Vogue |
16th May 2011 8:14pm |
I've never had success with a "visual inspection" of bushes etc. The RR is so heavy you just cant detect play. It's best when it's up on a ramp and you can put a 3 foot bar between the joints to detect play, or better still when the wheels are hanging. Any decent garage should do this.
16th May 2011 8:17pm |
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 |
I know the front has ball joints which are prone to wear and also anti-roll bar linkages which can cause this problem ! Had the same on my Merc S class and fitted 1 x cheap linkage on one side and 1 x genuine Mercedes linkage on the other - the genuine one lasted over 6 years - the cheap one 3 months ! Don't buy cheap parts it's not worth it in the end as you do the sam job twice |
16th May 2011 8:20pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
I would echo what Dan said. Get a jack under the offending corner and give it a good tug in all directions. The dodgy bush should show up when their is no load on it. |
16th May 2011 8:51pm |
Fitted the new antiroll bar linkage and had a good tug and pry on everything whist I was there - fault/noise still there and nothing evident Does the rear shocks have bushes at the top ? could these wear and how easy is it to remove a shock absorber ? |
13th Jun 2011 10:00am |
The top and bottom bushes that attach the hub assembly to the top and bottom wishbones are prone to wearing, check them. |
13th Jun 2011 10:36am |
Thanks - I will have a look this weekend coming - if the rain ever stops |
13th Jun 2011 10:55am |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 |
rain in sunny yorkshire!!!... Current: TDV8 (3.6) RRS HSE
13th Jun 2011 5:23pm |
Suspect it's the shock absorber - are they easy to change ? |
16th Jun 2011 6:47pm |
Shouldn't be difficult, looks like 1 bolt top and bottom, the top will be inside the boot area. You might have to remove 3 bolts from the top mounting plate but I wouldn't think it necessary. |
16th Jun 2011 7:30pm |
