Home > In Car Electronics (L322) > VERY STRANGE!!!!!
m10rng
United Kingdom 2004 Range Rover HSE Td6 Java Black
VERY STRANGE!!!!!
hey guys..
was driving along and my head unit started to go black and then back to normal several times.
after about 5 minutes it returned to normal.
went home left the car and came back about 5 hours later started the car and the head unit is working but its very strange..
what i mean by this is that its a different color and most of the options such as off road navigation and television are not there. even the on board computer is not working properly and is in a different font..
and the worst thing is that when i don't turn the main lights on the screen is a very ugly brown..
now that i could handle until i know what to do but just now a sudden loud alarm type noise came from the right hand side of the driver side... pulled over put my hand down the small compartment near the driver right knee and found a scart cable cover which i only pulled off and then on again and the noise disappeared.
are these two problems linked..
can any one help!!!!!!!!!!!!!!!!!!!!!
thank you
Post #68348 12th Jun 2011 11:27pm
the lcd screen on the range does fail sometimes and what you describe could be the start of that or something as simple as a loose connection...pics of the 'strange 'screen might help.
if its been raining hard where you are its possible that the alarm sound/screen fail could be due to water ingress in the electrics?..check for water in the rear near side cubby ..
the scart cover is the obd port used for diagnostics, could be a coincidence that when you fiddled with that the alarm went off....
Post #68354 13th Jun 2011 7:40am
stevegt
United Kingdom 2006 Range Rover Autobiography 4.4 V8 Cairns Blue
The front parking sensor buzzer is in the drivers foot well on all pr 06MY L322's. The alarm sound will probably originate from there as there is nothing else that produces noise in that area.
Steve 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior
Post #68358 13th Jun 2011 8:17am
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
When MY MKIII Sat Nav died due to water ingress this was the symptoms I got. I think the water ingress could well be damage from condensation rather than water leaking in.. it doesn't take much to screw up the circuitry. The caboin air evacuates the vehicle in the same rear compartment hence there is nothing stopping cold moist air being drawn in the condense on the hot units... and as this happens when the car is stationary then the air con won't be on to help. Just my opinion.
You will also most likely have lost the DSP option to. I'd suggest that a new / replacement MK Sat nav with the DVD would be the best solution. You will have all the missing options back then.
That Scart socket is infact a OBD socket but does look similar.. not a clue why it should buzz. 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #68415 13th Jun 2011 4:53pm
m10rng
i took some pictures guys.. how do i upload them (
Post #68526 14th Jun 2011 12:07pm
click on gallery under the big fullfat.com logo
on the black banner, click on upload photos
click on browse and select the picture on your pc/laptop
press continue four times and this will bring you into your album
select/click the picture you want and it'll increase in size
where it says bbcode full size, copy and paste that into your post.
Post #68528 14th Jun 2011 12:11pm
SteveMFr
Site Sponsor
or use another foto hoster like picshare or photobucket. The pics are only linked in.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #68530 14th Jun 2011 12:17pm
m10rng
Post #68531 14th Jun 2011 12:18pm
m10rng
thanx guys i hope this picture helps
Post #68533 14th Jun 2011 12:38pm
Ajay(UK)
United Kingdom 2015 Range Rover Autobiography SDV8 Indus Silver
The problem is definately with your sat nav computer - The blue screen you are seeing comes from the tv tuner and it "takes over" when the main nav computer is not working or functioning correctly.
Check the cables to the nav computer - you could try disconnecting them both and reconnecting which should reboot the nav which may solve it if not then sourcing a replacement from eBay would be your best bet and an ideal time to upgrade to a BMW DVD based unit Thumbs Up
Andy. 2015 L405 SDV8 Autobiography, Indus Silver with Black Pack.
SWMBO: 22MY Defender 110 HSE X Dynamic, Gondwana Stone.
Gone: 2014 Discovery 4 HSE Luxury Firenze Red
Gone: 2006MY Java Black TD6 Autobiography
Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats
Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE
Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD
Gone: 2003 Epsom Green 4.4i Vogue, LPG, Mk4 Nav, BMW Bluetooth Phone, Hybrid Tv Tuner,
Post #68534 14th Jun 2011 12:51pm
m10rng
o.k so just got the tools to take it out and open it up.. it looks like its been attacked by damp / condensation.. ill upload pictures
Post #68542 14th Jun 2011 2:54pm
m10rng
Post #68544 14th Jun 2011 3:06pm
m10rng
Post #68545 14th Jun 2011 3:06pm
m10rng
Post #68546 14th Jun 2011 3:07pm
m10rng
i looked up and found a company in sawston http://www.satchellelectronics.co.uk/ that may be able to fix it...
what shall i do gents???
Shocked
Post #68547 14th Jun 2011 3:08pm
