Home > General > disable my RR while away.
Benjerbustmills
United Kingdom 2012 Range Rover HSE TDV8 Stornoway Grey
hi
i really like my 4.4 tdv8 vogue hse.
trouble is, i’ve got to go to away, and have to leave my car in london, and i want to make it as difficult for some ars**ole to relieve me off my lovely rr!!
my plan is to remove the r10 relay, & probably the starter relay also.
my question is….
will the removal of these relays cause any problems, so when i reinstall them, all is fine!
cheers in advance
Post #683434 21st Jan 2024 4:06pm
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Hi, If you disconnect the battery before taking any relays out should be fine, just remember to put them in before reconnecting the battery.
In fact better remove the battery all together. I plan to remove the battery and the engine ECU as they're both together in mine, even if they did manage to bring a spare battery along they're not going to get away with simply slotting in a spare ECU.
Just remember, ECU first, then battery Thumbs Up Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #683437 21st Jan 2024 4:44pm
Benjerbustmills
Is it important to disconnect the battery before removing a Relay?
Just a simple question.
I agree it would be better to remove the battery but in this case it’s not practical.
Just looking for a fairly quick and simple solution.
Obviously, if they pick the damn thing up…. Well it’s gone!
Post #683478 21st Jan 2024 8:56pm
AndyRoo
Hi Benjerbustmills, it's up to you, I would say it's not strictly necessary but I've been on this forum long enough to know that they do strange things with the electrics if you mees with them when live.
Besides, how long do you think it would take we with my GAP tool in your ODBII port to know there was a missing relay causing the failure to start.
Come back in an hour with a relay, or swap one over, Bish Bosh, cars away.
As I said, up to you Whistle Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #683481 21st Jan 2024 9:16pm
dhallworth
Removing the battery and the ECU from a 4.4 TDV8 is not a 5 minute job.
It’s not difficult but it’s not something you’d want to be doing when leaving the car.
There’s no need to disconnect the battery before removing relays either. I’ve read online of cars being destroyed with Stanley knife blades when the thieves haven’t been able to make off with them.
L322’s aren’t keyless entry so they’re nowhere near as easily stolen as an L405. L322 theft is very rare and pretty much unheard of.
Post #683483 21st Jan 2024 9:38pm
JayGee
Sorry to inform you that neither of our 12 yr old RR's are worth stealing Big Cry 2012 TDV8 Vogue (L322)
Post #683500 22nd Jan 2024 8:41am
travel by train and leave the FF at home.. ... - .- -.
Post #683502 22nd Jan 2024 9:02am
AndyRoo
Ha Ha, yes, a bit like that, but I've changed so much on mine that every 5 years I'm actually a rotating a new car though my driveway piece by piece
Andy Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #683518 22nd Jan 2024 11:01am
Benjerbustmills
Thanks for your helpful comments!
It would be nice if you could rely on the train…
But you can’t these days!
I have a 405 as well as my 4.4 TDV8, but I think I will be selling the 405, and keeping the real RR.
So it looks like I’ll be removing the relay!
Of course IF someone wants it badly enough, they’ll take it. All you can do is slow the process down, make it more difficult, and hope they move on to something else.
Post #683521 22nd Jan 2024 11:48am
