![]() | Home > Wheels & Tyres > 19" vs 20" |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7865 ![]() ![]() ![]() |
I have 20s on my RR and I’ve not broken a wheel in a pothole, but I am careful going up kerbs and parking as there isn’t that much tyre to take the bang.
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2566 ![]() ![]() ![]() |
It seems that you should be looking for a vehicle that has the rear e-diff, then fit a tyre like the Duratrac to whichever size rims that it has, assuming they are either 19" or 20". If 20" then fit 255/55 rather than 255/50 and if 19" then maybe also consider 255/60 GG AT3, although the ride with these is harsher than usual. |
Tommaso_in_UK Member Since: 19 Jan 2024 Location: Berkshire, Great Britain Posts: 34 ![]() ![]() |
Thank you @mjdronfield and @GraemeS
255/55 are not factory standard. 255/50 are the normal tyre size for 20 inch wheels. 2011 Range Rover Vogue SE 4.4 TDV8
Can one use non std tyres in Great Britain? Will the insurance pay in case of accident? |
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 217 ![]() ![]() ![]() |
I’m running General Grabber AT3’s 255/55/20. Told my insurance company and it doesn’t make any difference. |
UK insurance companies are only interested in non OE wheel sizes but not non OE tyre sizes. The wisdom of this is obviously questionable…… 2012 TDV8 Vogue (L322) |
Fla Member Since: 26 Nov 2023 Location: South west Posts: 189 ![]() ![]() ![]() |
I was only contemplating this recently and you're feedback would be great. my new to me RR came with new tyres. They are not a brand I would have picked as the road noise is pretty bad. That said its a thousand euro I don't have to spend right now. That said, when I go to change I will probably go for Pirelli Scorpion. I'm currently on 255/50/20, Ive seen a bit about the 50 vs 55's but has anyone run both? Have you noticed a difference with comfort?
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 890 ![]() ![]() ![]() |
Having run both sizes on several L322’s (all Pirelli’s) I’d say you’d be hard pressed to tell the difference - adjusting the tyre pressures to suit your preference is more noticeable though.
A 'Harsh ride' is a common complaint with quite a few owners of L322 and L405 with the variable damper system and has been covered by extensive threads with so far no definative solution or explanation. 2012 TDV8 Vogue (L322) |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1393 ![]() ![]() ![]() |
My 2004 322 had 255/55R19 Pirelli scorpion zero, these worked fine as a road tyre, good balance between handling, braking, comfort, noise, fuel use. Poor on slippery surfaces off road, especially if towing.
Thank you, very useful 👍🏻 |
