Home > Wheels & Tyres > 19" vs 20" |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7840 |
I have 20s on my RR and I’ve not broken a wheel in a pothole, but I am careful going up kerbs and parking as there isn’t that much tyre to take the bang.
20th Jan 2024 8:19pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2536 |
It seems that you should be looking for a vehicle that has the rear e-diff, then fit a tyre like the Duratrac to whichever size rims that it has, assuming they are either 19" or 20". If 20" then fit 255/55 rather than 255/50 and if 19" then maybe also consider 255/60 GG AT3, although the ride with these is harsher than usual. |
20th Jan 2024 9:00pm |
Tommaso_in_UK Member Since: 19 Jan 2024 Location: Berkshire, Great Britain Posts: 34 |
Thank you @mjdronfield and @GraemeS
20th Jan 2024 10:49pm |
255/55 are not factory standard. 255/50 are the normal tyre size for 20 inch wheels. 2011 Range Rover Vogue SE 4.4 TDV8
20th Jan 2024 11:00pm |
Can one use non std tyres in Great Britain? Will the insurance pay in case of accident? |
21st Jan 2024 6:57am |
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 214 |
I’m running General Grabber AT3’s 255/55/20. Told my insurance company and it doesn’t make any difference. |
21st Jan 2024 9:02am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3283 |
UK insurance companies are only interested in non OE wheel sizes but not non OE tyre sizes. The wisdom of this is obviously questionable…… 2012 TDV8 Vogue (L322) |
21st Jan 2024 9:07am |
Fla Member Since: 26 Nov 2023 Location: South west Posts: 189 |
I was only contemplating this recently and you're feedback would be great. my new to me RR came with new tyres. They are not a brand I would have picked as the road noise is pretty bad. That said its a thousand euro I don't have to spend right now. That said, when I go to change I will probably go for Pirelli Scorpion. I'm currently on 255/50/20, Ive seen a bit about the 50 vs 55's but has anyone run both? Have you noticed a difference with comfort?
21st Jan 2024 10:32am |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 876 |
Having run both sizes on several L322’s (all Pirelli’s) I’d say you’d be hard pressed to tell the difference - adjusting the tyre pressures to suit your preference is more noticeable though.
21st Jan 2024 10:49am |
A 'Harsh ride' is a common complaint with quite a few owners of L322 and L405 with the variable damper system and has been covered by extensive threads with so far no definative solution or explanation. 2012 TDV8 Vogue (L322) |
21st Jan 2024 10:56am |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1388 |
My 2004 322 had 255/55R19 Pirelli scorpion zero, these worked fine as a road tyre, good balance between handling, braking, comfort, noise, fuel use. Poor on slippery surfaces off road, especially if towing.
21st Jan 2024 12:16pm |
Thank you, very useful 👍🏻 |
23rd Jan 2024 9:14am |
