Home > Maintenance & Mods (L322) > Handbrake being a bit arsey |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 877 |
Only takes a small amount of extra effort to back off the handbrake shoes adjuster and remove the locating screw to remove the brakes discs (rotors??) and inspect inside, often the shoe retaining pins / springs / pivots are in poor condition and may need cleaning or replacing.
21st Jan 2024 10:17am |
JoolsB Member Since: 16 Aug 2020 Location: The North Posts: 284 |
As JCW says, it’s worth the extra effort to whip the discs off and check the handbrake, the retaining pins and clips have a habit of rusting so a good clean up and some carefully applied grease should sort it out. |
21st Jan 2024 11:01am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3283 |
If it's just the flashing handbrake symbol on the dash then don't worry as this is common and seems to be cause by the suspension adjusting itself when parked for a long time / overnight. BTW you should realy change pads and disks at the same time and not put new pads on old disks esp at the rear as they don't apply much braking force and if rust gets hold on the unbraked area it will spread. 2012 TDV8 Vogue (L322) |
21st Jan 2024 11:02am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 |
Thanks JayGee, Jools & JCW
21st Jan 2024 5:38pm |
Interestingly, U2002-92 points to the switch
21st Jan 2024 6:04pm |
day before MOT:
27th Jan 2024 6:16pm |
