![]() | Home > General (L405) > Pre purchase inspection checks - what costly things to check |
Rex the RR Member Since: 15 Nov 2019 Location: Perthshire Posts: 43 ![]() ![]() ![]() |
Sorry if l missed but guessing it's a diesel? What engine? No expert but it may help others to comment. Front knuckles seem to be a hot topic! Obviously running any diagnostics, checking codes? Previous mot history? |
KILOCHARLIE Member Since: 18 Jan 2024 Location: Wales Posts: 9 ![]() ![]() |
Sorry, it’s a 4.4 diesel. I’ve done due diligence with MOT history and even paid for a car vertical check for the first time (which pretty much a waste of £30 as everything on it was available for free through lane rover or the dvla).
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
Oil leaks, oil leaks and more oil leaks! Coolant leaks from both the engine area and back towards the rear seat passengers, as these have 4 zone climate so have coolant lines to the rear seat passengers heater matrix... Corrosion on aluminium AC pipework held to the car using mild steel clips! |
Thanks, good tips! Yes I wanted to know the tyres from my first call about the car, it says so much. Luckily it has continentals all round, so many I saw previously described as “no expense spared” and then they have accellera tyres! I walk away on that basis alone! |
