Home > General (L405) > Pre purchase inspection checks - what costly things to check
KILOCHARLIE
Hi all, I have a pre purchase inspection booked in for tomorrow for a 2014 Autobiography I have put a deposit down on.
The garage isn’t a specialist as none could fit me in at such short notice, but he does overflow work for one and is (reluctantly) very familiar with all things LR related.
He’s asked for a list of anything I’d like specifically checked. Apart from the usual (he’s doing an MOT at the same time), what would you recommend him looking at?
Turbo’s? oil dilution? Air suspension? Any other common or especially costly faults on the L405 to particularly look out for? The mechanic only has an hour after he’s done the MOT. Confused
Thanks for any advice
Post #683144 18th Jan 2024 9:19pm
Rex the RR
United Kingdom 2019 Range Rover Autobiography 5.0 SC V8 Santorini Black
Sorry if l missed but guessing it's a diesel? What engine? No expert but it may help others to comment. Front knuckles seem to be a hot topic! Obviously running any diagnostics, checking codes? Previous mot history?
Post #683147 18th Jan 2024 10:15pm
KILOCHARLIE
Sorry, it’s a 4.4 diesel. I’ve done due diligence with MOT history and even paid for a car vertical check for the first time (which pretty much a waste of £30 as everything on it was available for free through lane rover or the dvla).
I’ve requested the inspector do a full diagnostics and also a test drive to check for any shuddering from the transfer box. I’ve told him to give it some beans too, check knuckles, diff leaks, oil cooler leaks and a battery health check.
If there’s anything else to advise him of it would be great. Looking online there’s nothing really to find and walk away from (unless it’s a complete lemon), but I’m hoping he can check anything that could turn out costly down the road.
Post #683150 18th Jan 2024 10:24pm
Oil leaks, oil leaks and more oil leaks! Coolant leaks from both the engine area and back towards the rear seat passengers, as these have 4 zone climate so have coolant lines to the rear seat passengers heater matrix... Corrosion on aluminium AC pipework held to the car using mild steel clips! Rolling Eyes
Worn brake discs & pads (genuine JLR brakes are expensive)...
Tyres are a dead giveaway... Cheap ditch finders will give you an idea just how she's been maintained...
Good luck Thumbs Up
Post #683154 19th Jan 2024 1:17am
KILOCHARLIE
Thanks, good tips! Yes I wanted to know the tyres from my first call about the car, it says so much. Luckily it has continentals all round, so many I saw previously described as “no expense spared” and then they have accellera tyres! I walk away on that basis alone!
Post #683164 19th Jan 2024 8:16am
