Home > Technical (L405) > L405 sdv8 coolant leak
FleXzoR
Belgium 2016 Range Rover Autobiography SDV8 Santorini Black
Hello,
I started working on my 2015 AB lwb 4.4sdv8 today, around 200k kms.
I have a coolant leak where the coolant is dripping from the bellhousing on the skidplates underneath the vehicle.
For some weeks i was already topping up the coolant regularly as i had time constraints to start working on the engine.
By pressurising the coolant system and having removed the intake manifold, i quickly diagnosed the bottom thermostat housing to be yet the first culprit.
Now, can someone point me to other possible/very common leak points so i can change/repair them while I'm yet in this phase rather then having to open everything again next year...
Something i have noticed, very few times, was a slight oil/burned diesel smell in the cabin.
I will be replacing the coolant pump already (bought new already).
Thanks for your help! MY2008 Buckingham Blue Supercharged - gone
MY2016 Santorini Black 4.4 SDV8 LWB AB
Post #682831 15th Jan 2024 9:56pm
Dolphinboy
EGR cooler
Post #682836 15th Jan 2024 10:37pm
GraemeS
Both sections of the thermostat housing, not just the leaking section, and all coolant hoses and fittings in the V.
Post #682839 16th Jan 2024 3:22am
FleXzoR
Hi,
Thanks. What connections on the egr cooler? Just the water connections? MY2008 Buckingham Blue Supercharged - gone
Post #682902 16th Jan 2024 5:23pm
ChrisJC
United Kingdom 2014 Range Rover Vogue SDV8 Aintree Green
I have changed both heater hoses and the little manifold assembly that they connect to.
Chris. L405 - 4.4SDV8 Vogue
P38 - 4.6V8 HSE
Land Rover series IIA V8
Post #682914 16th Jan 2024 6:25pm
