Home > Technical (L322) > Diesel Heater smoking.
daveturbo
My 2011 TDV8 4.4, Diesel heater on start up smokes very heavy for about 30 seconds then is fine, bit embarrassing as seams to do it at traffic lights or junctions doh. Anyone else have the same symptoms . Mercedes AMG w207
E class Cabriolet
Overfinch L322 4.4 tdv8
1987 sierra rs cosworth 3 door white.
1985 escort rs turbo series one.
1992 sierra sapphire 4x4 cosworth red
1993 sierra sapphire cosworth 4x4 silver
1993 sierra sapphire cosworth 4x4 white
1995 ducati 916sp.
Post #682643 13th Jan 2024 10:23pm
JayGee
Mine does it occasionally 2012 TDV8 Vogue (L322)
Post #682648 13th Jan 2024 11:49pm
TST717
My D4 does it although the RR 405 doesn’t ..!
Stops after short while…. Amazing bit of kit though!
T
Post #682655 14th Jan 2024 8:02am
daveturbo
Smoke
It seams to be loads better ,maybe because it has not been used for a while,thanks for the replies. Mercedes AMG w207
E class Cabriolet
1995 ducati 916sp.
Post #682767 15th Jan 2024 11:37am
jaguar3
Estonia 2011 Range Rover Vogue SE 4.4 V8 Baltic Blue
Need to replace a burning chamber.
Post #682784 15th Jan 2024 3:49pm
JayGee
Is a smoking FBH bad ? 2012 TDV8 Vogue (L322)
Post #682788 15th Jan 2024 4:15pm
jaguar3
No its not. But it's progressive, the burner is full of soot and going worst and worst. Soon it may be that it won't fire up anymore.
Post #682789 15th Jan 2024 4:32pm
JayGee
Can it be cleaned or is replacement the only option? 2012 TDV8 Vogue (L322)
Post #682790 15th Jan 2024 4:35pm
jaguar3
It can`t be cleaned. Its possible to replace evaporator mesh only, but for that you need to saw burning chamber apart and after replacement weld it back together. + new gasket 100%.
But quite often there is other issues like cracked or bended tube so you never know what you will find inside.
Best option is to find on Ebay brand new Webasto (250-350€). Not matter is it pre-heater or additional heater, diesel or petrol. Not matter is it Thermo Top C, E, Z or P. Burner*, blower and body will always be the same. In this case you will get compleatly brand new FBH. Just install your ECU and water pump.
* Petrol burning chamber can be used on diesel FBH, but not other way.
Post #682792 15th Jan 2024 5:01pm
jaguar3
https://www.ebay.de/itm/134884795465
Thisone for example. Its littlebit too expensive, but there is new water pump also included.
In sommer time there is much better prices.
Post #682794 15th Jan 2024 5:08pm
JayGee
Thanks jaguar3 - great info as usual Thumbs Up
I think I'll put up with the smoking for now. 2012 TDV8 Vogue (L322)
Post #682796 15th Jan 2024 5:22pm
