![]() | Home > Technical (L405) > 2018 L405 camera system failure |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1304 ![]() ![]() |
Do you have any DTC ? can they be reset?
Arbit Member Since: 18 Dec 2023 Location: London Posts: 10 ![]() ![]() |
No I don't know the DCT but I've ordered an OBD reader to find out.
This morning for example the reversing camera worked when driving away from home but when I parked up the car a few minutes later at the station it was the usual fault. Below are a few pictures I took yesterday.
Try charging your battery lots of Gremlins appear when the battery is struggling 2018 SE SDV8 4.4 Byron Blue |
I’ve charged my battery last night but my Noco Genius 10 immediately did show that the charge was 4 out of 4 so that shouldn’t be the problem.
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1644 ![]() ![]() ![]() |
Hoi! I resemble that remark! ![]() |
No not an easy fix--- As its an approved vehicle you should have JLR warranty so no need to delve further yourself---take it in to the dealer. In my WS manual it states your DTC as below U0046-83 Vehicle Communication Bus C - Value of signal protection calculation incorrect Invalid data received from another control module through the high speed CAN bus (chassis) NOTE: Do NOT install a new chassis control module as this will NOT rectify the fault Using the Jaguar Land Rover Approved Diagnostic Equipment, check the snapshot data to determine the invalid data source control module. Check the relevant control module for related DTCs and refer to the relevant DTC index But as a matter of interest ![]() Looking at my electrical drawing all camera's feed into the Camera control module -so could be a fault there? Also could be faulty ground on that module? Also there is a 5A fuse in rear JB (59R) Also a Flex ray bus feed (Bus C?) from Assembly BCM-GWM (Body Control Module-Gateway Module) probably this giving your error code. 2018 SE SDV8 4.4 Byron Blue |
Thanks a lot for your help, I shall proceed to get an appointment with the dealer to sort it out. |
CrabberOne Member Since: 19 Jan 2024 Location: Cornwall Posts: 6 ![]() ![]() ![]() |
Hi,
Sadly I had to use the LR warranty and they replaced the front camera and the camera module and then it all worked again. |
Thank you for your rapid response and I'm glad that your issue has been sorted.
