Home > Maintenance & Mods (L405) > Reverse light brightness poor |
Old-un Member Since: 12 Feb 2022 Location: Manchester Posts: 143 |
I have the same low reverse light problem but find it helps to see better quite a bit by turning on hazard lights when reversing. Just remember to switch them off after use. RR owner |
11th Jan 2024 8:53pm |
Or ------ how about a brighter light that is wired into a towing socket plugs reverse light terminal in one piece that can be removed when needed for trailer pulling ?
11th Jan 2024 9:18pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35331 |
this is old but a goody,
11th Jan 2024 9:26pm |
zenman63 Member Since: 14 Nov 2021 Location: Warwickshire Posts: 152 |
It does light up yes, I need to repair it as it did fit and look factory. When I rebuild it I will take pictures. My Trailer rolled back into it and amazing it survived! |
13th Jan 2024 4:01pm |
luxmoggy Member Since: 19 Jun 2020 Location: Trier Posts: 467 |
I am interested in how and where you wired it in. Looking at the lights available here.
17th Jan 2024 12:30pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1478 |
@Luxmoggy:
17th Jan 2024 2:28pm |
Here you go:
17th Jan 2024 2:32pm |
@Zenman63:
17th Jan 2024 2:54pm |
@Gremlin500
17th Jan 2024 7:21pm |
This seems to be the story of my Range Rover. I have a different part. As I have the deployable tow bar, I need a different cover (VPLGB0154), which of course isn't on AliExpress.
18th Jan 2024 12:36pm |
IGP Member Since: 09 Jul 2020 Location: Malvern Posts: 288 |
I have one you can have for cost of postage. But, postage may be a bit expensive.
18th Jan 2024 1:00pm |
It’s wired with a IP rated water resistant plug directly in the tow bar wires, very simple. |
18th Jan 2024 6:44pm |
The light comes in an acrylic strip and that needs to curve and the bumper panel is curved, only a bit but it’s not flat. I then bonded on the back. It only just fits as there is very little space behind it. I have ordered a new panel and will mill out another and take some pictures. |
18th Jan 2024 6:48pm |
I was looking at the panel today (I didn't take it off). The driveway is still wet and I didn't fancy undoing the screws - I don't want a bad back. But I can see there isn't much room.
23rd Jan 2024 10:52am |
