Home > Wheels & Tyres > L663 Defender alloys on the L405
Page 2 of 3 <123>
James W
Saudi Arabia 2017 Range Rover Autobiography SDV8 Siberian Silver
That's more like it Thumbs Up FFRR SDV8 Autobiography
Post #662269 19th Apr 2023 12:50pm
reviving this thread to ask if the defender wheels used bolts or nuts for these wheels..
i've seen a thread here saying that the new range rover L460 wheels use bolts so the 'normal' nuts used on the L405 do not fit properly , so a purchase of ford transit nuts is required..
wondering if the defender is the same as the L460.. ... - .- -.
Post #677406 6th Nov 2023 10:32am
fisha
I just used the existing bolts that were on the L405. V8 or else ...
Post #677410 6th Nov 2023 12:09pm
you mean nuts?
thanks for the info Wink ... - .- -.
Post #677413 6th Nov 2023 12:34pm
JAD
United Kingdom 2012 Range Rover Vogue TDV8 Epsom Green
I've seen a set of 5 of these at a really good price. Does anyone know whether they're OK on an L322?
Post #682271 9th Jan 2024 7:44pm
Jorrocks
United Kingdom 2018 Range Rover Autobiography SDV8 Montalcino Red
Would either removing and re-using the original TPMS valves or getting another L405 set work? I don’t have an IID tool, and anyway would prefer to have the monitoring functional. 2018 L405 4.4 SDV8 Autobiography
2010 L322 3.6 TDV8 Vogue SE, 171000 miles and counting….
Post #691145 23rd Apr 2024 12:55pm
fisha
Re-using the originals would likely work.
If you bought another set, I *think* they might need registered to the car using IID tool or similar. V8 or else ...
Post #691174 23rd Apr 2024 9:40pm
bdd123
United States 2017 Range Rover Autobiography 5.0 SC V8 Aintree Green
When you say take offs, I assume that means that they are not Land Rover wheels, right?
Are they 20x8.5 ET41.5? Current: 2017 L405 ATB, 2016 LR4 SE
Past: 2001 RRR H&H, 1993 RRC SE, 1989 RRC, 1990 RRC, 1995-97-98 D1
Post #691430 27th Apr 2024 7:58pm
Jorrocks
One more question, Fisha, if you don’t mind; What pressures have you settled on? The Defender runs 33 / 36psi, but I assume it’s considerably lighter than an L405! 2018 L405 4.4 SDV8 Autobiography
Post #691450 28th Apr 2024 8:22am
fisha
Good question … in short 33ish on the front and 37-38 ish on the rear ( I tow a horse trailer from time to time )
In answering this, I found out that my gauge on the inflator hose was over-reading by quite a margin. When reading 38, the tyre was actually 30. Noticed it cause there was a wee bit of bulge more than I thought there should be for that pressure.
New inflator gun and now back up to 38 and the ride is markedly better and feels smoother somehow ( despite the harder tyre … hey ho ) V8 or else ...
Post #691959 5th May 2024 1:17pm
Buz1500
United Kingdom 2019 Range Rover Autobiography SDV8 Carpathian Grey
In reply to the question raised by BDD123 regarding the term “take-offs”.
In the UK this refers to factory fitted wheels removed from new or nearly new cars by the main dealer or customising shop as part of an upgrade to a different LR wheel or 3rd party supplied wheel.
I’ve purchased “take-offs” a number of times from both LR dealers and customising shops and they can usually be purchased at bargain prices when compared to the new price.
I’d be interested to know if anyone has fitted the Defender style 5098 in dark satin to their L405. I had these on both of Defenders I’ve owned and they were great looking wheels and so easy to keep clean. 2019 L405 SDV8 Autobiography
2023 Defender P400e HSE X-dynamic - gone
2020 Defender P300 SE - gone
2019 Jaguar F-Pace SVR - gone
2013 SDV8 Autobiography - gone
2011 L322 TDV8 Vogue SE - gone
2006 L322 3.6 Vogue Se - gone
1999 P38 4.0 se - gone
199? Classic 3.5 - gone
Post #691993 6th May 2024 8:01am
fisha
The 5 spokes were what I really wanted originally, but the ones I got were too good a deal
. … i found the finish on mine as easy to clean as any other wheel to be honest. V8 or else ...
Post #692011 6th May 2024 12:47pm
Jorrocks
L663 take-offs now fitted. Extraordinarily good value, five wheels with new tyres for £400! Plus another £80 for a set of TPMS sensors and valves. Oh, and another £80 to fit the sensors and rebalance all five wheels.
Full size spare fits fine in the wheel well.
Handling is lovely, smooooth! That’s on 34psi front and 37psi rear. 2018 L405 4.4 SDV8 Autobiography
Post #692363 11th May 2024 3:29pm
Buz1500
I’m going to have to seriously look at getting some of these for my L405. I had the satin 5 spokes on my previous new Defender and I’d probably go for those. 2019 L405 SDV8 Autobiography
Post #692371 11th May 2024 4:49pm
dominicperry
United Kingdom 2016 Range Rover Autobiography SDV8 Aruba
That's quite a deal. Can I ask where you got them from?
And they look like 5095-style, is that right? I prefer those to the 5098s
Dominic
Post #692450 12th May 2024 1:45pm
Page 2 of 3 <123>
