![]() | Home > Technical (L405) > fbh temperature |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1438 ![]() ![]() ![]() |
I normally leave my temp set at 28' and that warms the cabin, so always nice and toasty when i get in, is that just luck or the right thing to do??
Arch Stanton Member Since: 26 Apr 2012 Location: chavshire Posts: 502 ![]() ![]() ![]() |
21 all round Doc, air con on First time FFRR owner |
try upping the dial to 28 and see what happens |
Thanks Doc
I will keep my fingers crossed for you. |
yours wont smell a bit dieselly every so often I guess, and it will sound better First time FFRR owner |
You are right doesn't smell and sounds like a jet engine taking off, just checked mine again and as long as temp dials are turned up then you should be good to go. makes sense as i use in summer to blow cool air. |
fingers crossed Doc, they're very quick to warm up but I'd rather get into a lovely warm cabin instead. First time FFRR owner |
So, million dollar question, did it work Arch? |
Nope, but I did have a low coolant warning (that went out 5s after car start). This happened a few weeks ago at -5dec C and the coolant level was fine. I’ve asked service dept to look while it is in. I suspect I may have a sensor that doesn’t like the cold and prevents the Fahd from starting First time FFRR owner |
I was in Oxfordshire yesterday morning with an overnight -6degree air temp, I'd set the FBH and it did come on but its effect was limited. There was a cleared area at the bottom centre of the front screen that was clear, an area about 25" x 10", the car wasn't warm but it was also not -6 either. It almost looked like it started but then stopped before it could finish its magic.
