Home > Technical (L322) > Alternator not charging
Kiwi_V8
New Zealand 2004 Range Rover Vogue 4.4 V8 Java Black
Hi its been a few years since I last had an L322 and I'm concerned I've made an error here!
The issue is with my recently purchased 4.2 L322
Battery light came on about 3 hours into a lengthy drive.
Managed to get it to a mates places. Battery voltage measured 12.7v engine off, dropped to 12.3 with engine running, so alternator is not charging.
Car is at the sparkies, alternator looks lnew (seller said it had been recently swapped out) and is bench testing fine, he is concerned it could be an engine ECU issue, which sounds expensive.
Any ideas what is going on here
Post #682128 8th Jan 2024 3:20am
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
Check your earth connections are ok can’t remember if it’s the 322 or 405 but one has a earth strap behind a front wheel liner that corrodes. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #682132 8th Jan 2024 9:29am
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
Hi,
V8 Bob is correct here is one of my earth points on left side looking at front of car :-
Post #682135 8th Jan 2024 11:39am
Kiwi_V8
So, it’s been checked over, earths were all good (thanks for the heads up), put back together and is working.
The alternator is a genuine item and looks to be in near new condition.
Concerns both my sparky and I that no actual fault has been found or fixed so feels like it may well happen again, thought being a dodgy connection somewhere. Autosparky is going to drive it around a bit and see if it breaks again.
Post #682211 9th Jan 2024 2:22am
timse
England 2010 Range Rover Autobiography Black 5.0 SC V8 Barolo Black
I bought a cigarette lighter volt meter and keep it plugged in. Really handy to just look down and check what the voltage is. Wink. Something like the below.
https://www.amazon.co.uk/Charger-Adapter-V...amp;sr=8-3
I had alternator issues on my old P38a so Made sure when I got my L322 that was the first thing I bought.
Post #682434 11th Jan 2024 2:37pm
Kiwi_V8
So, to close this one off, after a fair bit of investigation the new alternator was identified as being suspect.
It was a pattern part, so replaced it with a genuine item. drove 600km home today with no charging issues at all.
Post #682567 13th Jan 2024 2:18am
Tiny Timmy
Good idea I've ordered mine ...thanks... Thumbs Up
Post #682569 13th Jan 2024 7:39am
pcourtney
I ordered one a few days ago ( using Amazon ) and it arrived this morning, I plugged it in and my reading is only 12v, should I be worried, the car starts ok on the button MY11 (does not need a key) its push start !
Post #682591 13th Jan 2024 12:24pm
JayGee
12v is nothing to worry about. You can also monitor it via the secret touchscreen menu. The battery monitoring system is pretty sophisticated and will tell you if anything is wrong with the charging system. 2012 TDV8 Vogue (L322)
Post #682598 13th Jan 2024 2:16pm
timse
Mine reads 12v until you start the engine. It then goes to 14.6 or 14.7v depending on how long since last driven
Post #682677 14th Jan 2024 12:33pm
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
Thought we only had that in France...had my alternator replaced 4 weeks ago 600 euro and same problem. New one was not up to it's job. Seems that garages are all the same, they put in some sh...y new part that cost them small money and the "patient" wont check. If it works it's fine and they make good money. If it doesn't work they will discuss and tell you it's not their fault, some wiring problem, or what ever. Took some "convincing" but they replaced it with decent one. Now it's fine
Post #682741 14th Jan 2024 9:16pm
