Home > Technical (L322) > RetroFit Factory Phone |
As per the title I want to retrofit the factory phone kit.
8th Aug 2009 12:02pm |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2938 |
Mate, you're better off putting the BMW module in. See my post below- I've put a link to a site that explains it all 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
8th Aug 2009 10:14pm |
BMW? It's all BMW gear anyway isnt it? Just with a LR badge on it. As far as I understand it you cant have any telephone in the RR at all without the telephone control modue? If I'm wrong, great I can go down a cheaper road? |
8th Aug 2009 10:41pm |
The one in your pic is not a BMW unit.
9th Aug 2009 5:22pm |
The one in the pic is the ULF module though, not the actual control unit. If you dont have the conrol unit then your steering wheel buttons don't connect to anything... as everything is routed through it.
9th Aug 2009 5:26pm |
mmmm.... no mention of it on that website? Unless it assumes you already have it. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
9th Aug 2009 6:31pm |
From my understanding all of the instructions on that site refrence how to ad bluetooth functionality to your existing phone system. There is sketchy information on what to do if you do not already have a phone.
9th Aug 2009 7:08pm |
I've got wiring running up to the lid on my centre console- I can see it through the hinge.
9th Aug 2009 9:58pm |
Hmmm, bizzare. Maybe next weekend I'll pull the cubby box apart to see if its just not been pulled through. I'd be very happy if it is there - If it isnt I will scrap the whole idea because the loom obviously isnt there. |
9th Aug 2009 10:00pm |
This is the BMW unit
9th Aug 2009 10:04pm |
But that is just the Bluetooth ULF module? That would then connect to the phone module which in turn would connect to everything else as per the first pic I posted? |
9th Aug 2009 10:07pm |
No. It's not an addition to the existing set up. It's an "instead of".
9th Aug 2009 10:11pm |
RIGHT! That makes a lot more sense now lol! So that replaces the central unit.... I will still need a bluetooth antenna though, and appropriate gubbins for the cubby box? I wish I had enough money to just throw some cash at someone and say sort it out! Dan |
9th Aug 2009 10:17pm |
Yes. Bluetooth antenna is about £15 on eBay. Mic is £14 from BMW. I've compiled a list of all the required parts and part numbers, which I'll PM to you. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
9th Aug 2009 10:27pm |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6361 |
As the original PTI didn't allow for modern phones in the cradles and the bluetooth wasn't standard (I think?) would you not be better off installing a Parrot kit? My mate has one in his M3 (even tho the M3 has BT) and says its brilliant, plus it transfers the phonebook too, the LR one does NOT! Discovery 4 HSE
10th Aug 2009 9:45am |
