![]() | Home > Technical (L322) > 3.6TDV8 restricted performance issues. Advice needed |
Tiprat Member Since: 05 Aug 2021 Location: Manchester Posts: 92 ![]() ![]() ![]() |
Good afternoon Andy
Andy79 Member Since: 12 Oct 2021 Location: North Yorkshire Posts: 13 ![]() ![]() ![]() |
Hi and thanks for your reply.
Yes they are the ones, unfortunately I'm not with the car so I can't send you a picture. Borrowed Grey 2002 3d 204k for a year
willeywilson Member Since: 24 Feb 2022 Location: Staffordshire Posts: 4 ![]() ![]() ![]() |
Did you replace them Andy? Did it resolve the issue? I have the same issue, only when cold. It started with a cracked inlet manifold which I have temporarily bodged. I have found an EGR leak and have ordered blanking plates for both ends. I couldn't see any bubbles / holes on anything else when checking. |
johnny L322 Member Since: 06 Jun 2022 Location: Middlesbrought Posts: 3 ![]() ![]() ![]() |
Hi Guys,
Hi Willey No i haven't. I've not had chance to look at it yet. Thanks for the info , i will check it out once the weather improves. Cheers Andy |
hi i did get same code , turns out was crack manifold, and it happened in the middle of my europe trip 2k miles in 😂 , fix with some super glue and baking soda 🤣🤣
Hi Johnny, thanks for the photos. I did pay the garage to replace the valve cover/ inlet but I still have the error. Im guessing they cocked it up and cant be arsed fixing it. I dont know. I don't mind paying , but when it doesn't fix it and they say they don't know whats wrong with it what do you do ? cheers Andy |
well, I would find fault first, before starting to blame garage people! |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2943 ![]() ![]() ![]() |
Ive had the same problem since I bought ours back in 2019. I've just learned to live with it now. Sometimes it won't do it for 500 miles then other times, it's every time I go to work.
Check your valve cover for cracks properly, I found mine coz I spotted an oil mist around crack area , there should be no oil whatsoever.
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 750 ![]() ![]() |
I had the same problem on a 3.6, I changed all of the cheap bits and also a cracked manifold but had no improvement. I couldn't justify chucking any more money at it so I had the fault code written out.
BigMJ Member Since: 22 Dec 2024 Location: Devon Posts: 1 ![]() ![]() ![]() |
I am having the exact same issue on my 3.6 TDV8 that I have been living with for the last 3 years. Always happens on long hills where the engine is loaded at lower RPMs. Dropping a gear on known hills that trigger the limp mode always helps.
Hi,
