![]() | Home > General > What Did You Do In Your Full Fat Today |
Joff1961 Member Since: 24 Dec 2023 Location: Wroughton Posts: 1 ![]() ![]() |
Just put a new rear prop shaft on and still have the rumble I was trying to eliminate. Just close to 100K on the Westminster. |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 645 ![]() ![]() ![]() |
Figured out a way to stop the leading edges of the roof trim on both sides lifting and whislting in the wind at speed after the neanderthal that replaced the screen broke the retaining clips. Why would Land Rover make the plastic screws that hold it in place be hidden behind the headliner ?
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6746 ![]() ![]() ![]() |
Finally managed to wash my new acquisition for the first time since I got it.
Had- 2008 TDV8 Vogue SE in Java black Had - 2007 S/C in Stornoway Grey |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3247 ![]() ![]() ![]() |
Passed MoT. No advisories. Result |
Seatown Member Since: 30 Oct 2020 Location: Mountains, seaside Posts: 90 ![]() ![]() ![]() |
Took my folks home from NE to Central Scotland. Usual 3hr journey became 5hrs, making full use of off-road and extended off-road height practicing/honing wading skills through some of the worst flooded roads I've seen in 30 years. My 83 year old mother is now a FFRR convert! |
KitTheRam Member Since: 29 Mar 2022 Location: Essex/Herts Border (originally from Derby) Posts: 443 ![]() ![]() ![]() |
Got it dirty with some very light off roading on the way to a winter walk in Hertford Forest with the Mrs and kid.
Dutchgit Member Since: 17 Sep 2023 Location: Emmerich am Rhein Posts: 178 ![]() ![]() ![]() |
Fitted new discs and pads in the front today, also fitted a new membrane to the PCV/oil separator on the 3.6. Pads and discs easy, coated all surfaces with ceramic grease to reduce bonding in some places and reduce friction on the wheel nut/washers. No, I did not put that stuff on the wear side of the pads ! ![]() Taking out the PCV valve was a struggle for real as I didn't want to drop half of the coolant. It would have made the job easier but I couldn't be 4rsed. All the best for the new year peeps ! Oh, I test fitted the snow chains and it's a doddle with these.
Cheers, Ard |
Went for a drive today to bed in the new brakes a little.
Daz90 Member Since: 12 Nov 2023 Location: Bristol Posts: 40 ![]() ![]() |
Hopefully driving home in mine upon purchase today if the trains play ball! 😂 |
jamiej Member Since: 01 Dec 2023 Location: Surrey Posts: 52 ![]() ![]() ![]() |
I sorted the front end of mine with some eBay sourced letters.
Had to search on here for the positioning, as mine came with no guide. 32mm ish from the bottom of the bonnet lip to the bottom of each letter. 90mm ish between the E of RANGE and the R of ROVER. |
bob-lad Member Since: 12 Jun 2015 Location: Herefordshire Posts: 92 ![]() ![]() ![]() |
Not today, but passed the MoT on Friday. |
ChrisJC Member Since: 14 Sep 2023 Location: Northants Posts: 137 ![]() ![]() ![]() |
Went off roading. Did about 6 miles of forestry tracks and 4 miles of particularly degraded mine road. The forestry tracks were passable by a normal car, but the mine road definitely needed a decent 4x4.
P38 - 4.6V8 HSE Land Rover series IIA V8 |
MC-RR Member Since: 26 Jan 2022 Location: Monte Carlo Posts: 25 ![]() ![]() ![]() |
Drove the "Beast" up the Coastal Alps to check for snow. Fun drive from Monaco to Casterino passing through Sospel Casterino is about 1600m above sea level just above the village of Tende. A very pleasant drive and managed to get some off road driving in the snow.
Jaguar S type 3.6l Jaguar XJ8 Jaguar X type 3l Triumph TR6 1976 - Jeep CJ7 1976 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35533 ![]() ![]() |
just a reminder to members that this is a 'one' post thread so please dont discuss or reply to posts as this spoils the thread..thanks. ... - .- -.
