Home > Technical (L322) > Difficult Starting
JCM24
France 2010 Range Rover Vogue TDV8 Santorini Black
Difficult Starting
Hello All,
could someone help me to understand what happen ?
My 2010 L322 Vogue 3,6 get difficult to start the first time in the morning, let explain:
Pushing on the Start button, the engine begins to run 1 second and stops.
Try again, stops, try again it's OK.
No error message onthe dashboard.
The battery is full, starter is new and during the day, the car starts without any problem.
Just one thing: the diesel filter had been replaced last week. No leak, no smell. Possible relation?
Please help Bow down Bow down
Post #681092 24th Dec 2023 10:31am
Dutchgit
Germany 2008 Range Rover Vogue TDV8 Stornoway Grey
I had the same on my 3.6 two weeks ago when it was around freezing temperatures.
In the end I kept the key turned in the starting position until it kept running. Didn't take long, maybe 3 seconds or so and it ran and started like nothing ever happened before.
Post #681093 24th Dec 2023 10:38am
start button?
cheap to replace if indeed faulty ... - .- -.
Post #681098 24th Dec 2023 11:53am
JCM24
Thank you for your prompt answer Dutchgit !
There is no key on mine, just the start button, but I will try tomorrow morning to keep the finger a bit longer than now and keep you informed.
Happy Christmas
Post #681116 24th Dec 2023 3:21pm
JCM24
Hello Stan,
good idea, I will check.
Do you how to remove the button from the dashboard?
Post #681117 24th Dec 2023 3:23pm
you gently prise it out...be careful not damage the surrounding trim leather. ... - .- -.
Post #681119 24th Dec 2023 3:55pm
JCM24
Hello Everyone, I'back with the starting issue in the morning.
I was convinced that I had a pre-heating problem.
We tested all that was possible to test: nothing, no default, diesel pressure OK...
You remember that the diesel filter had been replaced recently ?
The starting problems had appeared the day after the replacement, so we replaced the new Mann filter by the old LR one (after serious cleaning...)
And now all is OK !!!!
I've bought a new Bosch filter, replaced yesterday and tryed to start this morning with ice on all the car...
Yep ! all is good.
Someone understand what happened ?
JC
Post #683172 19th Jan 2024 10:14am
D3Jon
Air in the system? Possibly nothing to do with the filter itself, but re-assembly and purging sorted the issue.
Just a thought? 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #683175 19th Jan 2024 10:22am
