Home > Technical (L405) > Temperature sensor
ABAB
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
Temperature sensor
Engine warning light prompted a trip to the dealer. They kindly looked at this for me the same day without a booking. No fix was done however as the replacement part needed is apparently on back order with no ETA.
Summary I was given was “… will require temperature sensor bank 1 sensor 1”.
I’m not sure where or what the sensor belongs to (exhaust or engine perhaps?). Does anyone know whether an alternative to a LR OEM part could be used for this.
I’ve been told that using the car in the meantime should be OK. However the nightmare that is the current JLR parts setup makes me nervous that this could be a long wait for a replacement sensor. 2016 SDV8 AB
Post #680997 23rd Dec 2023 10:32am
millerj90
I think this is the same sensor that I’ve just had replaced. If so, it’s the Exhaust Gas Temperature on the passenger side, it’s located in the manifold and is a mare to get to.
The tech who did mine didn’t have any problem obtaining one, but he did say that around this model year Land Rover decided to renumber all the sensors when viewed via ODB, so worthy a double check.
Post #681009 23rd Dec 2023 2:41pm
ABAB
Really helpful - thank you. Do you by any chance have the part number that was replaced on your car - not sure if it’s on the invoice perhaps? 2016 SDV8 AB
Post #681085 24th Dec 2023 10:51am
millerj90
I do have it!
The part number they used on mine: - LRO52169
There’s a thread here: - https://www.fullfatrr.com/forum/topic48131.html that discusses the topic of sensors.
Hope that helps.
Post #681087 24th Dec 2023 11:07am
ABAB
You’re a star - thank you. Had a very quick flick through the thread but it’s clearly one of the longest on this forum so might be a good read while I’m waiting for Santa later Very Happy
Interesting to see some mentions there of odd smells when idling which is definitely something I picked up. Seemed to me like a mix of exhaust fumes and binding brakes… 2016 SDV8 AB
Post #681090 24th Dec 2023 11:20am
