Home > Technical (L322) > Suspenssion high on the front
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
Asking for advice in where to look.
So the Range Rover went in for sill and arch work 5 weeks ago and a top job the body shop has done, it was picked up after the work and went to the next operation work at the local garage, the front subframe.
This has now been done, new mot and now mobile once again.....BUT.
Now I'm having air suspension faults, the front is higher than the rear by a considerable amount, when they where checking the sensors on their diagnostics it was showing the rear left not reading any signal.
They have changed this today and they recalibrated ( I think ) but the front is very high still.
Would a recalibration help or would it be better to lower the front only and not touch the rear?
I have the early Gap Idd tool (non Bluetooth)
Faults before the sensor change are as follows,
ox4 abs module rear left speed sensor plausibility
ox81 air susp can bus
ox82 tacho A missing signal
EAS ox64
1 articulation validity fault
2 ox32 can bus fault
oxbd ebv function fault received from ABS
transmission ox95 canbus speed general fault.
I must stress than NO faults where on the EAS before the work started as shes been very reliable in this area.
Any help would be greatly appreciated.
(with all thats gone on this year from house electric's, trailer brakes and my horse been hit by a car (she recovering) this is not what I need next) If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #680974 22nd Dec 2023 7:44pm
mjdronfield
Is the graphic on the 4x4 info screen showing the front as high?
Could one or both of the front height sensors have swung round when disconnected, so now have the elbow the wrong way so giving a false reading?
No other ideas, sorry.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #680975 22nd Dec 2023 7:48pm
Danb_220_2019
United Kingdom 2012 Range Rover Vogue SE TDV8 Fuji White
They did disconnect the battery whilst welding, I assume... 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Previous V8s: BMW 645Ci, P38 4.6, P38 4.0, Merc CL500
Previous others: Honda x1, Volvo x7, Rover x6, BMW x6, Ford x1, Mercedes x2, Skoda x3, VW x2, Renault x2, Citroen x1, Mazda x3, Nissan x1, Audi x3, Kia x1, Fiat x4, Subaru x3, Austin x2, Triumph x2, Jeep x2, Hyundai x2, Lexus x1, Mitsubishi x1, Saab x2... and some others I've forgotten!
Post #680979 22nd Dec 2023 8:32pm
Welshdragon
Thanks mjdronfield
The sensors all correctly facing the way they should, ie arm facing out wards and connecting rode vertical
Danb, yes they did disconnect the battery as I messaged him about the steering left/right thing after reconnecting.
It was level when I picked it up an all good. If it dont work.......burn it!
Post #680981 22nd Dec 2023 8:46pm
Paul H
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Stornoway Grey
after I swopped the front struts and ride height sensor I recalibrated mine (10 mins using the latest IID tool) not sure on the older ones. Worth a try? 2011 L322 Autobography - a lot of bells and some of the whistles...owner with no idea!
Post #681005 23rd Dec 2023 12:37pm
