Home > Technical (L405) > Check engine light on
Jase71
Australia 2017 Range Rover Vogue TDV6 Santorini Black
Just when I thought I was having a good run and booked airport parking for holidays next week and the check engine light is stuck on Big Cry
No change in performance and no idea what it is...these things always happen when public holidays are looming and stupid waiting lists for anything to be looked at... 2017 Range Rover Vogue V6 Diesel
2006 Range Rover Vogue V8 Diesel - gone
Post #680861 20th Dec 2023 10:18pm
Vogue
If there is no change in performance and no limp mode it’s likely to be a sensor fault - usually an Exhaust Gas Temperature Sensor - there seems to be an issue with this due to extremely poor quality sensors - Don’t ask me how I know 🙈
I’ve been left driving a vehicle with the lamp on for 3 months because LR had no sensors, no loan cars and no effing mechanic availability in the main agents - they have an absolutely
Horrendous backlog of warranty work that are a low priority as I’m told main agents don’t get the full charge out rate for warranty work compared to non warranty work
Charged to customers = your a low priority.
As for brand loyalty I’m on my 17th, I’ve never ever owned another make - quite frankly my patience is now wearing very thin. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #680864 20th Dec 2023 11:03pm
ABAB
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
Jase - sorry to hear that. I had exactly the same pop up a couple of days ago. Off to the dealer this morning to try and persuade someone to check the codes for it.
I’ve noticed a strong smell from the engine area a bit like exhaust fumes.
Not now expecting to be able to use the car over Christmas Sad 2016 SDV8 AB
Post #680879 21st Dec 2023 10:22am
Kot
Re: Check engine light on
Get a cheap scanner that can scans as well as reset fault conditions. Maybe it was a spurious event and can be cleared. Try these https://www.autelstore.co.uk/wholesale/aut...anner.html
You can also get them from amazon prime next day delivery for a few quid more. 2018 SE SDV8 4.4 Byron Blue
Post #680880 21st Dec 2023 10:27am
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
You can get this message for water in fuel which does not normally cause restricted performance. As above a cheaper scanner will generally provide the answer if not the full functionality of a iid tool.the advantage of the cheaper generic scanners is they don’t need coded to the car and can be used on other makes. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #680881 21st Dec 2023 12:13pm
Jase71
Thanks all. Going in tomorrow to see what the fault code says. Hoping I can use the car over Xmas! Will report back on the fault. 2017 Range Rover Vogue V6 Diesel
Post #680906 21st Dec 2023 6:38pm
ABAB
Good luck Jase. Mine is apparently due to a faulty temperature sensor. Went to the MD yesterday and was told that four people had already turned up there yesterday morning with warning lights lit up. All these lights maybe are a nod to the festivities! 2016 SDV8 AB
Post #680928 22nd Dec 2023 10:48am
Jase71
Okay, here’s the report..they suspect new turbo..check engine light off for now
Post #680940 22nd Dec 2023 3:00pm
hopefully under warranty.. ... - .- -.
Post #680941 22nd Dec 2023 3:02pm
Jase71
Nope..don't have the warranty.. Big Cry 2017 Range Rover Vogue V6 Diesel
Post #680942 22nd Dec 2023 3:03pm
dunc.reid@gmail.com
I’m no expert but that P0234-77 is usually a stuck or sticking throttle valve. This sometimes causes Nox and other errors as a knock on effect. I would check the throttle valve before committing to further work. Usually an easy check and worth a look anyway - just push the valve closed with your finger and it should spring back if ok - if not needs cleaning or ‘adjusting’ or even a new throttle body. Seen this idea on ‘Riley mobile mechanic’ on YouTube - he seems to fix a lot of Land Rovers with similar issues. Worth a look?🤷‍♂️ Good luck👍
Post #680978 22nd Dec 2023 9:18pm
Jase71
Do you know what, that's a good point. I had the throttle body replaced last year but even the new one has been the result of the car going in to restricted performance this year on a number of occasions. A clean has sorted it but this one confused me as no restricted performance. Just the steady check engine light. I really hope it isn't the turbo. 2017 Range Rover Vogue V6 Diesel
Post #680983 22nd Dec 2023 10:21pm
Jase71
Okay. Pulled the intake hose off and clean in and around the throttle valve. All was working perfectly and not sticking...just dirty. Maybe a small obstruction that freed up? 2017 Range Rover Vogue V6 Diesel
Post #681022 23rd Dec 2023 5:50pm
Thumbs Up That's a bit cheaper than a new turbo..... Pete
Post #681025 23rd Dec 2023 6:24pm
Jase71
Hope so..these things have a knack of making you feeling better for a few weeks before they come back! Shocked 2017 Range Rover Vogue V6 Diesel
Post #681026 23rd Dec 2023 6:26pm
