Home > Technical (L322) > Adaptive Dynamic Fault L322.
Mikem
United Kingdom 2010 Range Rover Vogue TDV8 Atacama Sand
Any recommendations in the kent area for getting the car plugged in to try and find the fault
Post #522301 20th Jul 2019 5:28pm
Baltic Blue
If any member has still got the old wiring, particularly the plastic plugs that fit into the top of the strut, please don’t bin them,... PM me and I will gladly pay postage for them.
Mike. (Baltic blue ) G reg 2.5VM Vogue Portofino red 1991- 1999
Post #522303 20th Jul 2019 5:32pm
GraemeS
Mikem wrote:
Checked the rears tonight no broken wires at the plugs so i think next thing is to get it plugged in and see what comes up Sad
It seems that breaks in the rear wiring aren't as obvious as the front breaks. If not already done, unplug each connector to check underneath the wires.
Post #522340 20th Jul 2019 9:11pm
timse
England 2010 Range Rover Autobiography Black 5.0 SC V8 Barolo Black
Andy B wrote:
Hi Mike, had this on my L322 S/C and fixed it with the wiring kit (x2). Assume it's the Adaptive Dynamics fault, not Active Dynamic. Happy to pop round and take a look depending on where you are in Kent!
Cheers,
Andy
Hi Andy,
Do you happen to know what the part number or where to get the repair kits please. I too have a L322 5.0 S/C 2010 that has just popped the error up on the dash so want to replace these cables on the front struts before anything else.
Thanks for your help
Tim
Post #539008 31st Dec 2019 2:16pm
Baltic Blue
Please don’t throw away the old plugs and grommets.
I can find a good home for them Bow down Bow down
Post #539011 31st Dec 2019 2:23pm
timse
Perfect, many thanks Mike Smile
Tim
Post #539015 31st Dec 2019 2:35pm
CaifanSC
United States 2012 Range Rover Autobiography 5.0 SC V8 Epsom Green
Did the OP ever find the fault? 2012 Range Rover Autobiography
91 BMW 850i 6 speed
94 BMW 850 CSi 6speed
Supercharged Tbirds
Audi S8, Audi V8 Quattro
Post #539221 2nd Jan 2020 5:51pm
FlyingTrotter
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
I have just had the Adaptive dynamic fault - pop up on the dash - my vehicle is a 2011 4.4 VSE and the terrain mode doesn’t work and it drives like there is no damping at all - very unforgiving
Is the consensus that this is a wiring between the suspension ECU or sensor issue that my independent Langley 4x4 should be able to address reasonably easily ?
Post #680533 17th Dec 2023 12:17pm
Baltic Blue
It’s usually a broken wire to the top of one of the front struts.
Very easy repair.
If I can repeat my plea from a couple of posts up, dated December 2019.
If anyone fits the new harness, please Don’t bin the old plugs and grommets.
I will gladly pay postage if you PM me.
Cheers
Post #680534 17th Dec 2023 12:32pm
Goldstar
2011 Range Rover Autobiography TDV8 Stornoway Grey
Mike.
Hi Mike, I may be being thick but I can't find that seller online. Would you have a link please?
Thanks Dec 2021- 2010 Facelift TDV8 4.4 AB in Stornoway Grey.
Post #680585 17th Dec 2023 10:04pm
Baltic Blue
You could ring Rob at Duckworths, mention the forum and quote the part number.
He will sort you out.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #680614 18th Dec 2023 9:25am
JayGee
Mine was caused by a loose connector to a height sensor. I fault scan with a GAP IID tool or your indy should locate the component that has failed. 2012 TDV8 Vogue (L322)
Post #680619 18th Dec 2023 9:49am
FlyingTrotter
All sorted - was fortunate to be able to get them to spare the time to check and it was a broken wire to the front story - all now right again - Bloomin fortunate as have a shoot just after NY
Thanks everybody for the info - really helpful
Post #680697 18th Dec 2023 9:23pm
