Home > Technical (L322) > Check engine light 2008 3.6 - no faults showing |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3195 |
There are some options in the advanced menu of the fault code section of the tool and AFAIK the 'pending fault' is off by default so maybe worth turning this on. Not saying it will identify the fault but worth having it. Failing that the team at GAP are very good at answering questions by email and respond quickly so that's worth a try. 2012 TDV8 Vogue (L322) |
13th Dec 2023 10:14am |
Leigh4571 Member Since: 09 Oct 2021 Location: Shropshire Posts: 14 |
Thanks, I don't think I am reading the engine ECU's so will contact the GAP team |
13th Dec 2023 10:16am |
Check the advanced menu for the faults and I think there is also an option to check all ECU's. Also look at the PDF manual you can download. 2012 TDV8 Vogue (L322) |
13th Dec 2023 10:47am |
Used the laptop to check and update the Tool and now have a full list of ECU’s including the engine
13th Dec 2023 3:27pm |
EIther of those solutions would work but you may need the EGR valves mapping out if it's an electrical fault. AFAIK you can do this via teh GAP IID tool ( for a fee) 2012 TDV8 Vogue (L322) |
13th Dec 2023 3:46pm |
Thanks, blanking kit ordered.
13th Dec 2023 9:52pm |
