![]() | Home > Technical (L322) > 2005 4.2 SC coolant leak |
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 526 ![]() ![]() ![]() |
I had a leak at the front of the engine a ew months ago. I couldn't see the source because there is too much stuff there, but it was dripping off the front subframe directly below the oil filter housing.
JackPeters125 Member Since: 05 Jan 2023 Location: Wiltshire Posts: 22 ![]() ![]() ![]() |
Ah ok. That pretty much sounds the same. Oil filter was soaking. |
By the way, when I had mine done, I had the belts and tensioners etc changed as he had to take off some stuff from the front of the engine for the waterpump.
Thanks for this. I was thinking the same around replacing parts whilst replacing the Waterpump. |
Just to update anyone searching for this. It was indeed my water pump leaking so it has been replaced.
