![]() | Home > Technical (L322) > 6HP28 Possibly Juddering |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1000 ![]() ![]() |
I think the EDS2 solenoid current would be useful as an additional measurement (albeit at the cost of a reduction in sampling frequency) so that we can see what the torque converter lock-up clutch is being told to do (i.e. off, controlled slip or locked solid)
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3188 ![]() ![]() ![]() |
Thanks Phil,
At road speeds such as 65mph & 80mph you’d clearly expect the lock-up clutch to be fully engaged (i.e. locked solid) and therefore the engine and turbine speeds would be identical. As they aren’t, this would appear to be a LUC issue.
Thanks Phil, your input is massively appreciated. I’ve been chasing my tail thinking this was an engine fault after I’d done the timing chains and not getting anywhere with it.
Gentle acceleration up through the gears would show the point at which the LUC is applied and then the transition from controlled slip mode to fully-engaged.
A run at constant speed in top gear would also be useful to check if the engine speed wavers if the LUC is fully engaged. Phil |
My IID tool isn’t doing anything with the solenoids unfortunately despite changing the firmware as suggested by Patrick
2012 Range Rover 5.0 SC Autobiography in Indus Silver with Jet/Ivory Interior 2012 Range Rover 4.4 TDV8 Autobiography in Baltic Blue with Sand Interior 2013 Range Rover Sport SDV6 HSE Black Edition in Santorini Black with Ebony Interior |
This is the whole list is what can be monitored from the Transmission ECU using SDD.
That’s very disappointing. So it isn’t looking like we’ll get to the solution through diagnostics, and replacing the torque converter is obviously a big job. I just wondered if it might be worth replacing EDS2 first, on the off-chance that it’s a solenoid fault causing the issue, before resorting to major surgery?
I was beginning to wonder the same thing if I’m honest.
The yellow cap & blue cap solenoids from the 6HP26 are the same parts used for the 6HP28, but the 6HP26 didn’t use the orange cap solenoids. The function of the orange cap solenoids is the same as the yellow cap (i.e. increasing pressure with increasing current), but the inlet and outlet ports are reversed, so they aren’t interchangeable.
Thanks Phil, I didn’t remember seeing the orange cap ones which now makes sense!
Although I can see why it would be tempting to change as many of the solenoids as possible while you’re at it, especially if you have much newer ones lying around, I’d be concerned that this may lead to further complications as all the pressure & time adaptions would initially change and the controller would be trying to adjust the shift times for all the clutches at once. If you possibly can, I would just try to stick with the single solenoid change (EDS2) so that we can immediately see if it has any effect.
pjw888 Member Since: 04 May 2023 Location: Dumfries Posts: 30 ![]() ![]() ![]() |
Hi guys,
Thanks Phil, PM incoming |
