Home > Maintenance & Mods (L322) > height sensor |
Clip? The electrical connector? The bracket can be a pain….
2nd Dec 2023 4:56pm |
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 395 |
yea the electrical connector............got the old sensor off ,new one on but the connector is another thing |
2nd Dec 2023 7:10pm |
So you can’t get the connector to go into the new height sensor?
2nd Dec 2023 7:19pm |
yea 3 pin ,there are clips to hold connector secularly on to the sensor .it just wont clip in going to have a another go tomorrow(depending on weather ) |
2nd Dec 2023 8:19pm |
Yes, best to attack it again tomorrow, snow permitting. Save getting too annoyed with it. Did you get a genuine one? Though should still fit. I think one side may have curved edges so it will only fit one way, but you will be beyond that stage I imagine…. Can’t think of anything else… sorry…
2nd Dec 2023 8:49pm |
Epson Green Member Since: 20 Mar 2021 Location: Sutton Coldfield Posts: 111 |
Check the orientation, they only fit one way. Kevin
3rd Dec 2023 5:39pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3201 |
They are not easy to remove and I had one that was not locked in properly which caused an intermittent adaptive dynamics fault . I blasted out the socket and plug with WD40 and got it to latch which not only resulted in no more faults but also a much smoother ride...... 2012 TDV8 Vogue (L322) |
3rd Dec 2023 7:14pm |
Yea genuine Range Rover part ,the old one was a bit to get off contacts cleaned with electrically cleaner,the contact will slid onto sensor but just won’t go in far enough for clips on the side to engage and hold in place |
3rd Dec 2023 9:11pm |
