Home > Maintenance & Mods (L405) > Trickl charging battery
Plumbman
United Kingdom 2016 Range Rover Vogue SE 3.0 SC V6 Corris Grey
Can you use a trickle charger on a landrover L405
Post #679055 29th Nov 2023 6:38pm
caymanblack
Mine is on one 24/7 connected to the terminals under the bonnet. overfinch modified
Post #679057 29th Nov 2023 6:43pm
Plumbman
Thanks for the reply, Any issues and how long have you used this? JD
Post #679059 29th Nov 2023 6:52pm
Gremlin500
#2
Ours is on a CTEK MXS5 24/7 for the past 18mths, it’s the way to go for a car not used daily for longish trips, the CTEK will take care of itself, just don’t ever use the “recond” setting with an AGM battery.
You can wire the remote socket to the posts in the engine compartment, I have my socket install in the little lower front grille:
 “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #679064 29th Nov 2023 7:20pm
CS
If you have towing electrics one can get adaptors that plug the trickle charger in there which is the most convenient method as far as I am concerned. Only Range Rovers since 1988
Post #679066 29th Nov 2023 7:24pm
Gremlin500
This charger:
Post #679070 29th Nov 2023 7:35pm
Plumbman
Thanks for the prompt and useful replies, what’s AGM battery .? By the way. Cheers. J D
Post #679077 29th Nov 2023 9:31pm
RRV8SC
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
Gremlin500 wrote:
#2
What is the reason for not using “recond” with the AGM battery?
Post #679078 29th Nov 2023 9:32pm
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
It won’t help anything because the Recond mode is designed to mix up the separated acid and water in flooded batteries, and AGM batteries aren’t flooded, so that separation doesn’t happen:
https://www.upsbatterycenter.com/blog/unde...batteries/
I think it’s gel batteries that the Recond mode dries out.
Post #679080 29th Nov 2023 10:11pm
Gremlin500
AGM = “Absorbent Glass Mat”
In other words the acid in the battery isn’t a free-flowing liquid like a conventional (“flooded”) battery.
It’s rather like the acid is absorbed by a large brick of blotting paper, preventing the liquid from sloshing around inside the battery.
The “recon” mode should NEVER be used with an AGM battery, because the voltage in that mode is too high a continuous voltage for that type of battery (15.8V vs max. 15.4V) and will shorten the life of the battery. Unfortunately it IS possible to set the CTEK in “AGM RECON” mode, which is incorrect, even though in the instruction manual this is greyed out for AGM mode:
Note: The initial Stage 1 “Desulphation” mode of the CTEK will also reach 15.8V, BUT this is not continuous for a long period, only short pulses for a short time, so will not harm the battery.
Believe me, I have researched this exhaustively, after trashing a 1-year old AGM battery on another vehicle by using AGM/RECON during Winter storage, battery went from 100% to 29% SOH in 12 months, if you don’t believe me, well go ahead and try RECON/AGM yourself, it’s only £200 for a new battery Laughing Twisted Evil “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #679091 29th Nov 2023 11:32pm
Plumbman
Many thanks gremlin and to the others who took the trouble to reply. J D
Post #679271 2nd Dec 2023 12:31am
RRover
2012 Range Rover Westminster TDV8 Causeway Grey
Any thoughts on the CTEK CS FREE booster?
It is a few squids more but the breakdown boost start ability is a tempting addition...
Was considering the seemingly more popular MXS 10 before researching the above...
Whistle
Post #679722 7th Dec 2023 6:22pm
Do you have a very long extension lead for when you do go out....???
Sorry couldn't resist.... Pete
Post #679724 7th Dec 2023 6:27pm
AnnualMan
Switzerland
I’ve had the CS Free for a few year now and I can tell you it’s pretty disappointing. I thought it was the solution to keeping my BMW X1 12v topped up without the need for an electricity socket in the garage. The reality was despite the cars battery being in decent nick, the CS Free would drain its battery to empty in under 24hrs.
CTEK couldn’t have been less helpful, giving vague answers or none at all. A lot of money for nothing more than a battery booster when you’ve got a flat IMO. 2018 P400e AB LWB
Post #679737 7th Dec 2023 7:30pm
RRover
(AM)
"I’ve had the CS Free for a few year now and I can tell you it’s pretty disappointing. I thought it was the solution to keeping my BMW X1 12v topped up without the need for an electricity socket in the garage. The reality was despite the cars battery being in decent nick, the CS Free would drain its battery to empty in under 24hrs.
CTEK couldn’t have been less helpful, giving vague answers or none at all. A lot of money for nothing more than a battery booster when you’ve got a flat IMO."
Cheers for your input AM... Thumbs Up
Maybe food for thought...
Oddly enough as I keep seeing that the item appears to hold the LR produced tag (?!?) the mention of reactions of: ""Couldn’t have been less helpful, giving vague answers or none at all."" This would fall right in line with my total experience of LR to date - totally useless once vehicle purchased!
Post #679768 8th Dec 2023 9:07am
