Home > Technical (L322) > Suspension Struts & Air Bags
Mike Edwards
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
Hi,
I need to replace my front strut on my 2011 and would appreciate some advice regarding brands to avoid.
Aerosus
Arnott
Britpart
BWI
Dunlop
JLR
I've not heard good things about Dunlop and Britpart but that could be unfair.
Any experiences and suggestions would be most welcome.
Thanks.
Post #678974 29th Nov 2023 11:52am
dingg1
Got aerosus front complete units on mine about 6 months ago
No issues so far....
Post #678975 29th Nov 2023 11:58am
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
BWI on mine and no issues so far!
Post #678976 29th Nov 2023 12:12pm
Bingo_123
my vote for BWI, no issues since installed 2 yrs back.
order from site sponsor Duckworts for a good discount and next day delivery.
Post #678977 29th Nov 2023 12:16pm
mjdronfield
BWI vote from me….
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #678978 29th Nov 2023 12:23pm
kevinp
Dunlop. Very smooth and compliant softer ride.
Post #678982 29th Nov 2023 12:40pm
Danb_220_2019
United Kingdom 2012 Range Rover Vogue SE TDV8 Fuji White
OEM BWI CVD struts from Maltings for me. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Previous V8s: BMW 645Ci, P38 4.6, P38 4.0, Merc CL500
Previous others: Honda x1, Volvo x7, Rover x6, BMW x6, Ford x1, Mercedes x2, Skoda x3, VW x2, Renault x2, Citroen x1, Mazda x3, Nissan x1, Audi x3, Kia x1, Fiat x4, Subaru x3, Austin x2, Triumph x2, Jeep x2, Hyundai x2, Lexus x1, Mitsubishi x1, Saab x2... and some others I've forgotten!
Post #678985 29th Nov 2023 1:48pm
pcourtney
OEM BWI CVD struts from Maltings also - very good so far Smile
Post #678998 29th Nov 2023 3:06pm
Merchy
Same thoughts as Kevinp, my Dunlop items have been problem free.
Post #679032 29th Nov 2023 5:54pm
JayGee
Mine are still working after 165k miles so I guess BWI make a pretty reliable unit. 2012 TDV8 Vogue (L322)
Post #679033 29th Nov 2023 5:57pm
Paul H
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Stornoway Grey
Thank god we have a search function as literally just came to post the same question!
I guess the cold weather highlights these issues 2011 L322 Autobography - a lot of bells and some of the whistles...owner with no idea!
Post #679101 30th Nov 2023 8:35am
Paul H
Aerosus are doing a pair with VDS for £708.60 delivered, anyone seen any better deals - discount code SAM15 is still working on the site and his reviews of them seem very favourable - am ready to make the order unless anyone tells me that I shouldn't Smile 2011 L322 Autobography - a lot of bells and some of the whistles...owner with no idea!
Post #679107 30th Nov 2023 10:45am
Mike Edwards
Thanks for all the advice.
I went with BWI in the end as I needed something quickly and it was alleged they make the OEM units.
I had previously thought I had an air bag problem but after buying a replacement and removing the strut I found that the strut was knackered and the original air was still good.
Of course, buying a strut without an airbag seems nigh on impossible.
Oh well, hopefully the BWI will arrive today.
Post #679112 30th Nov 2023 10:58am
Mike Edwards
BWI strut, etc. arrived but I’m a little confused by the airbag connection.
The original has a brass bush that holds the pipe and screws in to the air bag.
The replacement also has a brass bush but with a white plastic insert, almost as if the air line should push in to it.
Obviously I need to remove the hose from the old bush, or cut it off, and then find a way to push the hose in to the plastic insert that is the same size as the hose.
Any and all hints and suggestions welcome.
Thanks.
Post #679394 4th Dec 2023 12:29am
GraemeS
Australia
The white plastic insert is just a plug to keep the bag inflated and to keep rubbish out until fitted.
Post #679402 4th Dec 2023 4:29am
