Home > Maintenance & Mods (L322) > Re inflating air suspension procedure |
Wiltshire130 Member Since: 05 Aug 2023 Location: Wiltshire Posts: 21 |
Cannot give a definitative answer to your question but if you did a 4 wheel lift normally with pressure in the bags the suspension would droop to its lowest position normally so I would assume exactly the same would occur if you reinflated in your current mode.
26th Nov 2023 6:21pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Yep, it'll be fine - BUT, don't expect the car to support itself as all it will do is inflate the bags to the gallery pressure, once the load is on the air suspension it will drop to the bump stops. When we do this on a lift, we inflate, then introduce some (i.e.) not full load by lowering the vehicle onto axle stands or wheels, allow the suspension to re-level, then carry on doing whatever else needs to be done. |
26th Nov 2023 7:05pm |
Epson Green Member Since: 20 Mar 2021 Location: Sutton Coldfield Posts: 107 |
Nice looking job on the subframe - on my list to do. Did you just lower it or take it off the vehicle completely?[/quote]
26th Nov 2023 7:19pm |
I just did my fronts - all arms and joints. I posted yesterday about the tool/method I used to remove the ball joints in the knuckle if you are interested.
26th Nov 2023 7:41pm |
Many thanks, excellent information ๐๐ Kevin 2012 L322 Westminster 4.4 TDV8 1999 P38A 4.0 SE - Sold |
27th Nov 2023 10:32am |
[quote="Wiltshire130"]I just did my fronts - all arms and joints. I posted yesterday about the tool/method I used to remove the ball joints in the knuckle if you are interested.
27th Nov 2023 10:38am |
