![]() | Home > Technical (L405) > Searching for coolant leak |
Funnily enough, just traced a coolant leak on mine, this was from the degas pipe at the top of the coolant radiator, it was dripping onto the top of the radiator & tracking down a wiring harness into the OSF wheelarch, with a bit of a whiff of coolant from that area.
ChrisJC Member Since: 14 Sep 2023 Location: Northants Posts: 132 ![]() ![]() ![]() |
Could be one of a million places where there's an o-ring. I have done 3 leaks so far on my 4.4 SDV8. The basic issue seems to be that the o-rings go flat, and the plastic surface on which they seal rubs down with engine vibration creating a groove.
Just a thought - the FBH is on that side and the valve won't always be in the same position with the engine off - maybe time to take covers etc. off and look for residue? OAT coolant doesn't evaporate like water does and tends to leave white / pink residue when it dries due to heat, so once you've got the covers off and hoses etc. exposed, finding it should be fairly quick, especially if it's been losing >1 litre every 90 miles or so. |
Bigfella70 Member Since: 22 Jan 2016 Location: Yorkshire Posts: 106 ![]() ![]() ![]() |
Thanks for the advice and suggestions gents. I think some covers need to come off for a look at these areas. Will report back on findings! Current
Seatown Member Since: 30 Oct 2020 Location: Mountains, seaside Posts: 90 ![]() ![]() ![]() |
I had a similar issue on mine, no evidence on the ground, etc but eventually traced it to a leak in one of the pipes into the thermostat housing. Coolant was leaking into the V of the block and being burnt off so no drips under the car.
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1408 ![]() ![]() |
The key for me tracing it though was throwing some UV dye into the coolant tank ( I think in the end I put 2 small bottles into it - bought off amazon ), and going round with a UV light in the darkness afterwards.
Thanks for all the advice.
UPDATE:
