Home > General > L322 advice |
Daz90 Member Since: 12 Nov 2023 Location: Bristol Posts: 40 |
Great to hear! Thanks too for the suspension purchase tip |
24th Nov 2023 12:44pm |
Awesome! Just the kind of suspension viewing advice I was after! Many thanks Jon |
24th Nov 2023 12:45pm |
Love the spec of yours too! Exactly the same as what I will be viewing |
24th Nov 2023 12:47pm |
Definitely something I wouldn’t have thought of doing. Thank you very much 👍 |
24th Nov 2023 12:49pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2265 |
The water ingress is usually from the rubber round the tailgate they do wear I have replaced mine twice and its an easy fix |
24th Nov 2023 1:16pm |
Thank you. I am certainly hoping that’s the case |
24th Nov 2023 3:20pm |
Hi all,
26th Nov 2023 6:50pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3246 |
Unlikley you can remove sill trim to inspect but it's easy to see the wheel arches and tailgate and look uderneath for the general state of rust but you will be lucky to find one that is rust free by now so keep your expectations realistic. 2012 TDV8 Vogue (L322) |
27th Nov 2023 9:08am |
Thanks JayGee,
27th Nov 2023 9:46am |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 435 |
Best not to dismantle the car until after you've bought it! In all seriousness though, it's not really possible to remove the trim without breaking the fixings (they're a bit fragile). As said, rust on upper tailgate lower edge is easily spotted. Rust on rear arches can be seen with rear passenger doors open, look at the edge that's about 12mm (1/2") wide, disapearing intowards the wheel - that's where they go first. If they're bad then the corrosion spreads to the front part of the rear wings as well. Just look at pictures of older examples on Facebook or Ebay for an idea! Good luck with the viewing! Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
27th Nov 2023 10:37pm |
Cheers Jon,
27th Nov 2023 10:41pm |
The wheel arch edges are a good place to check for general 'rearward' L322 corrosion. That's not to say they haven't been re-painted previously, but then that's also a sign of a caring owner! It's not a certainty that's it's not got to the cills though if the arches are good. But it's unlikely.
28th Nov 2023 9:27am |
Thanks Jon,
28th Nov 2023 9:37am |
Hi all,
29th Nov 2023 5:28pm |
