![]() | Home > Maintenance & Mods (L405) > Knocking rear headlining |
All the wiring above the head lining is either glued to the headlining or fixed in place with fir tree clips, the harness is wrapped in a fleece tape. There are magnetic strips that hold the headlining in place, so no clips to work loose as such. Have you tried it with the pan roof blind in different positions? It could be the B or C pillar trims reacting to different temperatures or one of their clips not fitted correctly. If you take it in, get photos of the headlining, blind & internal pillar trims prior to any work... |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8554 ![]() ![]() ![]() |
Or, god forbid, the pan roof drain has rusted off and is slapping about, is the headlining above the rear door damp in wet weather...??
