Home > Technical (L322) > 5.0 Supercharged Hesitation
Sandyt
David I had something similar on my 4.2 and it turned out to be a pressure sensor that had an intermittent fault we found it by chance
Post #676530 26th Oct 2023 8:53pm
dhallworth
Cheers Sandy.
I had to remove the MAP sensors to send the Supercharger away for rebuilding, you can’t buy the o-rings on these so I refitted them with the old ones. I’m wondering if it could be something as simple as them leaking.
Will see what I can find. Thumbs Up
Post #676548 26th Oct 2023 10:59pm
Floopy
I recently had this on my 4.2 stuttering under high load conditions such as climbing a hill with a heavy load or full throttle in a high gear, even stuttered enough to go into limp mode but with no fault codes showing on the IID. Fine in all other conditions though, even hard acceleration if the load was not too high.
I suspected a coil so on the IID I loaded the live missfire values, all were zero in normal driving but if I manually selected a high gear and used heavy throttle the stutter started and the missfire counter for cyl #4 shot up to 70. I repeated this a few times and every time it was the one cylinder so I swapped the coils on cyls #4 and #2. Went out for another drive, repeated the test and sure enough, #2 was now stuttering so it's a faulty coil.
In all other tests the coil is fine, but failing under load. Annoyingly all 8 coils were replaced by the PO not that long ago and this is the 2nd one that has failed, they were sold as Lucus too. I'm replacing them with NGK now.
EDIT: Sorry I've just seen you aren't showing any missfires, so possibly not the same issue. NB. mine only showed missfires on the live values, not stored. 2006 L322 Vogue SE 4.2
Post #676551 26th Oct 2023 11:18pm
dhallworth
I’ve not driven the L322 for about a fortnight now so I took it for a run tonight. It was meant to be booked into the local specialist for a high pressure smoke test today but due to a tech having a family emergency they had to cancel and rebook.
I’ve taken a lot of readings with the IID tool.
The airflow readings are not far apart from each other. I don’t know if they’re far enough away to be causing issues though.
These are the injector pulse widths when sitting on cruise control at 70:
These are the injector pulse widths as the hesitation is occurring:
These are my long term fuel trims. I took this screenshot of the IID tool on 25th October and I can’t remember if it was at idle or whilst driving. I guess on the long terms it shouldn’t make too much difference.
Bank 1 is perfectly within spec but Bank 2 is the one that’s not right.
I’m thinking that I might swap the MAF sensors around and see if it makes any difference to the fuel trims. It’s an easy thing to change and should let me see if the fault follows the MAF very quickly. I’ve also bought a pair of pre-cat oxygen sensors that I need to fit to see if they make any difference. I’ll make these changes one at a time though so I can be certain of which one cures it.
The fact it’s doing the same thing with all 4 injectors on Bank 2 and it’s also trying to lean it out makes me fairly confident that it’s not an injector fault.
I remember seeing this thread a few months ago and wondered briefly if it’s possible I have early signs of a failing fuel pump, however, my fault is only affecting one bank so I’m fairly happy to rule that out as being my fault too. I’ll have a good sniff underneath the oil filler and see if it smells petroly as that may help rule this out too.
https://www.fullfatrr.com/forum/topic65565-15.html
As far as faults that only affect 1 bank of cylinders goes, I’m thinking Air Leak, Air Flow Meter or Oxygen Sensor.
Anybody able to think of anything obvious I’m missing?
Thanks,
Post #678032 16th Nov 2023 12:07am
dhallworth
After a bit more reading this morning, I’m convinced it’s the MAF sensors. I could be wrong, but there’s my logic…
I read a thread on Jaguarforums.com where someone was troubleshooting a rough idle on an F Type R. He posted this:
“MAF readouts show exact figures on both sides so I assume they are both fine then.”
Looking at mine, I initially thought they were similar but they’re actually 2100g (2.1kg) of air apart.
Bank 1 reads 70560g/hr whereas bank 2 reads 68400g/hr.
If the ECU thinks Bank 2 isn’t getting the air it should then it’s probably going to think Bank 2 is running rich. Bank 2 is the one that’s getting a negative fuel trim.
I’m going to order a pair of Denso MAF sensors and will fit them and the oxygen sensors I’ve got over the next few days and see what’s what.
Post #678040 16th Nov 2023 9:52am
Rackers
Does the fuel pressure rise when you switch the engine off?
When my HPFPs were shot I had the same hesitation and generally rising fuel trims, a sure way to tell is pressure dropping at engine off rather than rising.
Post #678349 20th Nov 2023 3:00pm
dhallworth
Thanks for the suggestion.
I’ve got a blanking plate on order that lives on the back of the supercharger which due to LR moving warehouses I’ve been told will take approximately a week to arrive.
I’ll check the fuel pressure when I can start it again. Did you find your oil level was increasing when your pumps were leaking past? The one thing that made me discount them as being the cause was both of your fuel trims were negative whereas only one of mine is. It’s also stationary at -12.5 and isn’t getting far enough to put the EML on.
I take it the IID tool will monitor fuel pressure at shut down and not just loose comms when you switch the car off?
Thanks,
Post #678404 20th Nov 2023 11:44pm
Rackers
My oil level did increase but it took its time to show on the digital gauge, it was most notable when doing the actual oil change.
The IID will continue to monitor for at least 5 minutes (that's only as long as I needed).
Fair point regarding the trims, the injector values look ok as well and that's an expensive and long winded route to go down on a whim!
Hope you get to the bottom of it, car is looking great! Thumbs Up
Post #678412 21st Nov 2023 7:53am
dhallworth
I’ve done 100 miles in the car today and can report the following:
After replacing both MAP sensors, both oxygen sensors, both MAF’s and both air filters the fuel trims appear to be much more in sync with each other.
When switching off the car, the fuel pressure does increase gradually over a period of time.
After the most recent spate of work, the car feels smoother and sounds happier when sitting on the motorway on cruise.
However, the hesitation is still there. It only seems to occur when under load at low RPM. It’s more noticeable when accelerating gently in 3rd gear from 1500 - 1800rpm.
It feels like a misfire, however, the IID is logging zero catalyst damaging, or emissions related misfires. I monitored them over 15 miles on the motorway and when climbing a hill whilst the hesitation was obviously occurring.
Back to the drawing board by the looks of it.
Post #678723 25th Nov 2023 7:29pm
dhallworth
I’m wondering if I’ve been going about this the wrong way…
When I can feel the hesitation/stutter, there are no misfires or anything being logged. At all other times the engine feels amazingly smooth and powerful.
I’m wondering if it could be transmission judder that I’m feeling. I’m going to go for a drive with my IID tool connected shortly and see if there’s anything untoward when monitoring the speed sensors in the gearbox. If the torque converter is causing it then I’m half expecting to see the hesitation mapped in a graph of the speed sensor reading.
Will report back later on. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #678775 26th Nov 2023 4:24pm
dhallworth
Ok, it looks like it’s not something that’s gearbox related. You can see on the attached video that whilst the engine revs are fluctuating the gearbox input speeds are rock solid.
Before we headed the 100 miles home earlier this morning I reset the engine adaptions as I’d forgotten on Friday before we left. I had a look at those tonight.
Here’s the fuel trims from before I replaced all the sensors:
Last week I fitted the following:
2 x Denso Mass Airflow Meters
2 x Land Rover Pre-Cat Oxygen Sensors
2 x Mahle Air Filters
1 x Bosch MAPT sensor (Back of Bank 2 Inlet Manifold)
1 x VDO MAP sensor on the front of the Supercharger
After doing 100 miles since resetting the engine adaptions, this is what I’m looking at tonight.
On the back of the inlet manifold for Bank 1 there is a part which Land Rover call a blanking plug. (Pictures borrowed from Google Images).
This blank is only fitted to cars that aren’t fitted with the symposer as it connects to the same port. It’s the only part that has a rubber seal on it that I’ve not changed so far. The rubber seal for this isn’t available separately so I’ve ordered the whole assembly at £51 as you can see how the seal gets flattened over time.
As you can see from the screenshot above, the oxygen sensor is now seeing Bank 1 running lean so it’s adding fuel to even out the mixture. If the seal on the blanking plate was allowing unmetered air into Bank 1 then it would be running lean.
I ordered this blank on Monday last week from our local dealer but thanks to JLR moving their parts warehouse into Mercia Park, they are quoting stupid lead times for parts at the moment. Hopefully it arrives soon so that I can get it fitted and see if it cures the problem. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #678814 26th Nov 2023 11:00pm
chefkenmore
Scotland 2014 Range Rover Vogue SE SDV8 Loire Blue
Needle in a haystack springs to mind!
You will find this……………………… Thumbs Up 2014 vogue se
Post #678867 27th Nov 2023 7:32pm
Awall13
United States 2012 Range Rover Supercharged 5.0 SC V8 Santorini Black
Did you happen to find a resolution to this? Old thread but mine just started doing this on the way to work, odd hesitation at low rpm under load. Doesn’t really feel quite like a coil to me but that was my first thought.
Post #697645 8th Aug 2024 3:08pm
dhallworth
I did indeed.
See this thread here:
https://www.fullfatrr.com/forum/topic68557.html 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #697653 8th Aug 2024 5:51pm
