![]() | Home > Technical (L322) > 5.0 Supercharged Hesitation |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8509 ![]() ![]() ![]() |
It made no difference I could tell but worth checking this pipe....
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3179 ![]() ![]() ![]() |
Cheers Pete.
qwerty Member Since: 21 Oct 2015 Location: Bristol Posts: 60 ![]() ![]() |
Hi David,
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1364 ![]() ![]() |
Look at misfire counters being logged on the iid tool, coil pack on its way out imo at certain conditions
Ah only skip read. Didn't see you had looked at misfires, can't edit on phone.
I’ve cleaned both MAF sensors and the throttle body this evening. Starting with the simple things first.
I’ve just driven from home to Costco. All the way to the Kingston Bridge (18 miles) the car was absolutely perfect. Crossed the flyover at the airport in 6th gear at 1200rpm up the slope with no tugs or hesitation so I was quietly confident that it was fixed.
I'd suspect the coil pack if it's misfiring after being stuck in traffic and it's got hot. This is going way back but on software monitoring for another car I had it was possible to record ignition misfire events but not sure if the GAP IID tool can do this? 2012 TDV8 Vogue (L322) |
Managed to sort my IID tool out today.
Popped in to see the local JLR specialist today. Explained what was going on with the car, explained that there were no misfires, both MAF sensors were giving very similar readings and that the fuel trims were off from where I'd expect them to be.
Yep, those fuel trims are way out if you reset adaptions 29 miles before, it only takes a short drive for them to stabilise, and I agree an air leak is the likeliest as they are positive numbers....
I’ve not checked the fuel pressure actually. It doesn’t give any issues when under wide open throttle and using full power so I assumed they were ok.
The IID says what is being called for and the sensors tell you what it's getting, so a quick, easy check... |
Had a quick peek tonight at the fuel pressure.
