Home > Technical (L322) > Servotronic Valve / Hydraulic Transducer |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35290 |
take off the off side front wheel and its there tucked behind the plastic...undo the two long screws, take old unit off and replace the little filter, put new on and then check your steering fluid .. |
9th Jun 2011 8:51am |
kriswilson Member Since: 05 Oct 2010 Location: Aberdeen Posts: 106 |
Grr. Think I may be blind
11th Jun 2011 5:20pm |
Number 2 in the image below
11th Jun 2011 5:40pm |
Doh!! See it now, behind the A frame.
11th Jun 2011 5:56pm |
re the mesh filter use a same size bolt end to push it square in.. |
11th Jun 2011 6:02pm |
Success!!
11th Jun 2011 6:56pm |
11th Jun 2011 7:14pm |
Aurrian Member Since: 29 Aug 2011 Location: Glasgow Posts: 107 |
Hi guys
6th Jul 2012 4:37pm |
i'd get a mobile mechanic come to your home.. ... - .- -.
6th Jul 2012 6:06pm |
Don't be tempted to fill it with cheap fluid or you could run into more expensive problems |
6th Jul 2012 8:38pm |
robbo770 Member Since: 10 Jan 2010 Location: Aberdeenshire Posts: 467 |
If you have so so access and at least 1/2 inch of bolt to grab, buy a stud remover that fits on your socket set.
6th Jul 2012 8:43pm |
Sometimes it's cheaper letting the professionals do the work |
6th Jul 2012 10:08pm |
Thanks for the suggestions.
7th Jul 2012 12:06pm |
nubbin Member Since: 23 Jan 2012 Location: Sheffield Posts: 231 |
I've got the same problem - I need to replace the valve, but both bolts are completely seized. The Torx heads are rusted so that a torx fiting wont grip, and lots of GT85 etc isn't helping. the access problem doesn't help either. I guess I'll have to get a professional to do it, just when I thought I could get away with a quick DIY swap. |
7th Jul 2012 11:08pm |
