![]() | Home > Technical (L322) > Servotronic Valve / Hydraulic Transducer |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35499 ![]() ![]() |
take off the off side front wheel and its there tucked behind the plastic...undo the two long screws, take old unit off and replace the little filter, put new on and then check your steering fluid .. |
kriswilson Member Since: 05 Oct 2010 Location: Aberdeen Posts: 106 ![]() ![]() ![]() |
Grr. Think I may be blind |
Number 2 in the image below
Doh!! See it now, behind the A frame.
re the mesh filter use a same size bolt end to push it square in.. |
Success!!
Aurrian Member Since: 29 Aug 2011 Location: Glasgow Posts: 107 ![]() ![]() |
Hi guys
i'd get a mobile mechanic come to your home.. ... - .- -.
Don't be tempted to fill it with cheap fluid or you could run into more expensive problems |
robbo770 Member Since: 10 Jan 2010 Location: Aberdeenshire Posts: 467 ![]() ![]() ![]() |
If you have so so access and at least 1/2 inch of bolt to grab, buy a stud remover that fits on your socket set.
Sometimes it's cheaper letting the professionals do the work |
Thanks for the suggestions.
nubbin Member Since: 23 Jan 2012 Location: Sheffield Posts: 233 ![]() ![]() ![]() |
I've got the same problem - I need to replace the valve, but both bolts are completely seized. The Torx heads are rusted so that a torx fiting wont grip, and lots of GT85 etc isn't helping. the access problem doesn't help either. I guess I'll have to get a professional to do it, just when I thought I could get away with a quick DIY swap. |
