Home > Technical (L322) > Following fault codes
Simran0211
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Santorini Black
I have the following fault codes on my 4.4 TDV8
P0814-01 (2F) Transmission range display circuit malfunction - General failure information - general electrical failure
U2101-00 (2F) Control module configuration incompatible
U2300-64 (2F) Central configuration -
Algorithm based failure - signal plausibility failure
U2101-56 (2F) Control module configuration incompatible - System programming failure - Invalid / incompatible configuration
Any help would would greatly appreciated
Post #678173 17th Nov 2023 9:40pm
Phoenix
What is the concern / symptoms?
The U codes can be caused by hardware issues so address those first. P0814-01 is a detected hardware fault, if there is no specific malfunction or concern, clear the codes down, drive for a while and see what comes back.
Many vehicles will detect transient 'faults' that are transparent to the driver, if there is no noticeable defect or reduction in capability / performance of systems, don't worry about it.
Post #678179 17th Nov 2023 10:17pm
Simran0211
I’ve tried to clear the codes but they are persistent little Censored the engine and box pulls well even with almost two hundred bricks in the boot and two bags of cement. I was more curious 🧐
Post #678197 18th Nov 2023 12:51am
Phoenix
Have you tried changing high to low range & back again? does the range indicator illuminate?
Post #678202 18th Nov 2023 7:17am
Simran0211
Yep I done that aswell
Post #678215 18th Nov 2023 11:08am
