Home > Maintenance & Mods (L405) > Tow hitch query
j_rov
Tow hitch query
I have the genuine "Multi height tow hitch" which is essentially a 2" receiver with a tow hitch plate.
It's brand new, so no wear.
I notice that there is some movement of a few millimetres up and down and a little less side to side when fitted.
This is incredibly noticeable when towing as the trailer weight will cause loud clunks when changing direction, going over bumps etc.
So, question is, is that normal? If so, anyone tried a fix of any kind? __
2018 L405 3.0 TDV6 Vogue SE Fuji White
2000 4.6 V8 HSE Oxford Blue
1994 3.9 V8 Vogue Ardennes Green - resto project
Land Rover History:
2010 3.6 TDV8 Autobiography Stornoway Grey
2001 Discovery 2 TD5 GS
1999 Discovery 2 V8i XS
1994 Discovery 300Tdi
1993 Discovery 200Tdi
1989 Range Rover Vogue SE 3.5EFi
1976 Series 3 2.25
1977 Range Rover 2 door 3.5 Carb
Post #677859 13th Nov 2023 4:21pm
Bora20
Canada 2013 Range Rover 5.0 SC V8 Santorini Black
I have used this with previous vehicles. Works perfectly to hold the 2” tube tight in the receiver. Takes about five minutes to install or remove.
https://www.princessauto.com/en/anti-rattl...0008465957
There are other solutions too.
https://www.curtmfg.com/towing-accessories/security/anti-rattle Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #677860 13th Nov 2023 4:57pm
CS
Later versions of this have an anti-rattle bolt on the right side as one faces the back of the car which is tightened in order to stop the rattling. Apart from a tendency to rust and so need to be replaced from time to time it works well enough. A picture of mine was posted by Red Merle and you should be able to find it using the search function. I would have thought that drilling and tapping a hole in the side of the receiver and buying an appropriate bolt and locknut would work just as well. The standard bolt is a bit short, so when tightened to the recommended torque there is no movement possible in the locknut, so a longer nut than standard might be better.
PS Looking at that thread (search "tow", author Red Merle) again the picture has disappeared, but I referred to ownerinfo/landrover.com for MY2017 where there is a diagram showing the anti rattle bolt. As you (OP) have MY2018 I'm surprised your towbar does not have it, but maybe it is a pre-2017 version. Only Range Rovers since 1988
Post #677864 13th Nov 2023 5:22pm
j_rov
These were my immediate thought but looks like a tight fit. Will need to measure __
Land Rover History:
1976 Series 3 2.25
Post #677870 13th Nov 2023 6:23pm
j_rov
I have that bolt. It does resolve most of the horizontal movement, but it's the vertical that's the annoying sound/feeling.
Thanks, read the post and will have a look at getting what Red merle got. __
Land Rover History:
1976 Series 3 2.25
Post #677871 13th Nov 2023 6:26pm
CS
Surprising that you are still getting movement when the bolt is tight, I don't get that. Only Range Rovers since 1988
Post #677875 13th Nov 2023 7:00pm
ABAB
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
I have a similar vintage towbar.
Never had a problem with the anti-rattle bolt - provided it is tight enough.
Recently had to remove the bolt and wire brush it as it seems to rust quicker than everything else in its surroundings. 2016 SDV8 AB
Post #677917 14th Nov 2023 9:18am
j_rov
I've ordered one of the clamp things. Will report back if it's any good! __
Land Rover History:
1976 Series 3 2.25
Post #677926 14th Nov 2023 10:30am
Bora20
The clamp will fit. It can be installed in any of the four positions if needed. Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #677944 14th Nov 2023 3:32pm
supershuttle
I'm sure I just used an old credit card - but maybe not, maybe I just put up with it. I certainly didn't spend any money. On my very first Range Rover the tow hitch was just rusted in so it didn't rattle at all in fact the bastard didn't move at all - so there wasn't a problem apart from the fact that it annoyed me because I couldn't remove it. Geoff
Post #677952 14th Nov 2023 4:22pm
Norman.D.Seagull
United Kingdom 2015 Range Rover Autobiography SDV8 Loire Blue
Just a question regarding my 2015 SDV8 Autobiography - I understood the car came as standard with an electrically deployable towbar . Fortunately my days of towing horse trailers is done but had occasion to be asked to tow a trailer only to find on closer examination that whilst all the deployment buttons are situated on the right hand side of the boot there was no tow bar to be seen underneath apart from a loose connection block . I dont think the previous owner towed anything so he might have sold the unit or it could have been removed during a service Rolling Eyes I am sure they are eye wateringly expensive if they can be bought as an aftermarket . Any suggestions on this would be welcome.
Post #677957 14th Nov 2023 4:40pm
baz000000
England 2016 Range Rover Autobiography SDV8 Loire Blue
I always figured they came as an optional extra. It's an expensive item to fit as you need the hardware and also a module to operate it. I had fitted a detachable towbar to my 16 plate autobiography just over a year ago for a little over the £1k from memory.
Post #678421 21st Nov 2023 11:58am
j_rov
Definitely an accessory or optional extra at build stage.
The wiring is there already and listed as Tow Preparation in the specification, although the deployable tow bar needs additional modules and wiring afaik. __
Land Rover History:
1976 Series 3 2.25
Post #678423 21st Nov 2023 12:16pm
Norman.D.Seagull
Thank you for the responses- I will give it a miss for the time being!
Post #678424 21st Nov 2023 12:25pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Have seen this?
https://www.ebay.co.uk/sch/i.html?_from=R4...p;_sacat=0 2017 SDV8 4.4 silicon silver AB
2012 TDV8 4.4 Stornaway Grey AB
2011 TDV8 4.4 Buckingham Blue
2012 VW V6 3.0 Tougreg
Post #678430 21st Nov 2023 1:39pm
