Home > General > Potential New Owner - L322 vs L405 - Advice Please |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 808 |
Your budget should get a really good condition MY 10-12 4.4 TDV8
12th Nov 2023 7:56am |
Tdtj Member Since: 29 Sep 2021 Location: Edinburgh Posts: 187 |
The six million dollar question l405 l322 you are always going to get biased opinions on what we drive I had an l322 bought it with 150000 on the clock and all that I remember going on it was the serpentine belt other than that proved reliable. I only changed because of the low emission zones popping up here and there so changed to my current 2016 l405 which I love,had it since march and already I have covered 13000 miles of trouble free motoring
12th Nov 2023 8:31am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3249 |
For that budget I'd go for an L322. £20k for a mint low miler and £5k as a contingency fund. £25k seems a bit low for a 'sorted' L405. 2012 TDV8 Vogue (L322) |
12th Nov 2023 10:50am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7812 |
Irrespective of the othe comparisons, would the L322 tow better with it being a bit heavier?
12th Nov 2023 12:15pm |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 820 |
Just popped up - nice SDV8 for sale £20k
12th Nov 2023 12:34pm |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2576 |
Regarding the towing issue, again all subjective. I have an L322 and an L405, IMHO the 322 tows better (1.5T horse box and 2.5T loaded), the 405 is not in anyway bad though, just doesn't feel as solid, which may be me not really gelling with the 405 and my wife loving it 2013 L405 Autobiography Baltic Blue
12th Nov 2023 1:52pm |
There you go. Problem solved. 2016 4.4 diesel |
12th Nov 2023 1:59pm |
JamieShand13 Member Since: 07 Nov 2023 Location: Yorkshire Posts: 8 |
Thanks for the help folks, it’s very much appreciated!
12th Nov 2023 3:50pm |
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 590 |
IMO you've just got to be lucky (or more specifically not unlucky). I've had 4 over 16 years. The first was a nightmare, second an angel, third excellent until it suddenly wasn't (end of year 4), and fourth all good so far. You're more likely to get a good one than a bad one, particularly if you select well - but in the end that's where you need to not be unlucky.
12th Nov 2023 4:23pm |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 367 |
Oil coolers tend to leak, you can fit new gaskets but replacement is normally the best option. Rev it over 2,500 so second turbo kicks in and look for smoke…second turbo as standard doesn’t have a oil drain so it can build up then needs burnt off…they don’t all do it, mine didn’t then started! A oil drain mod is available at circa £1,000. Starter motors often fail, not easily spotted till they are going then you get a click as solenoid doesn’t click in a bit like a poor battery.
12th Nov 2023 4:58pm |
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 398 |
I can´t comment on the L405, but I´m 5 years into running a ´12 4.4 TDV8 L322, it's used for everything. Trips up to the folks in the Pyrenees, supermarket runs, towing, airport runs everything in between and it's been fabulous. DPF warning light came on once in that time, but that was due to COVID lockdowns and simply not being able to run the car enough during the winter.
12th Nov 2023 5:06pm |
Proftinkerpot Member Since: 22 Dec 2022 Location: County Antrim Posts: 182 |
A lot of your decision between L322 and L405 comes down to personal opinion. The L322 obviously went out of production in 2012 so they arecgetting on in years. For me, I wanted an L322 as a bucket list car and whilevi know the L405vis probably a more luxurious and better on road offering, there is something more traditional and analogue about the older model.
12th Nov 2023 5:28pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7944 |
There's always strong support for the L322 - and I've had several, but I prefer the L405 in almost every way. I've towed with both fairly regularly and I couldn't really tell the difference, they are both great tow cars.
12th Nov 2023 5:32pm |
MonkeyMan Member Since: 20 Apr 2021 Location: Ascot Posts: 133 |
Comparing a 322 to a 405 gets interesting answers as there are serious advocates of both. I would compare it to Star Trek: Its a bit like the Original Series vs The Next Generation.
12th Nov 2023 8:24pm |
