Home > In Car Electronics (L322) > Dash Cams for the L322
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Any recommendations for the MY10-12 front and rear dash cams?
I was thinking about the LR dash cam for the L405, but am told it is incompatible with the L322…in particular with the Nav unit
Post #677756 12th Nov 2023 8:50am
Phoenix
I've used Thinkware dashcams for years - now on the F880Pro. Works well, good image quality and night vision. the rear camera comes with a cable that is plenty long enough for Range Rovers and can be pulled through the tailgate grommets reasonably easily. The front camera is unobtrusive and doesn't have one of those pointless screens on it.
Not cheap (I got one on offer at £280) but well worth it when you have an 'incident' where the other driver can be seen on their phone....
The parking function proved it's worth when a couple of scrotes were identified trying car door handles on the street, the Police (for once) did use the images against them, they were apparently good enough to meet the requirements for positive identification despite no close-by street lighting.
Post #677765 12th Nov 2023 10:11am
Arch Stanton
England 2018 Range Rover Autobiography SDV8 Corris Grey
I have a lesser model Thinkware that I don't use the park function and the pictures are great First time FFRR owner
Post #677774 12th Nov 2023 12:45pm
garyRR
Any old dash cam will be useful to prove non-fault. They tuck quite nicely behind the rear view mirror, out of sight for the driver. 2015 Range Rover Autobiography 4.4 SDV8
Post #678074 16th Nov 2023 3:21pm
agree with Gary..
dont get conned into buying an expensive dashcam, an adequate one can be bought for around £30/40...
you will find that after the initial novelty of having one runs out you wont touch it for months or even years.. ... - .- -.
Post #678080 16th Nov 2023 3:59pm
garyRR
I forgot to mention, you may find this useful. I wrote a how-to for both mid and late cars:
https://www.fullfatrr.com/forum/post602206.html#602206
Mercifully, this is quite an easy job on an L322.
General rule of thumb with cheaper Amazon dash cams:
1080p = 720p
2k = 1080p
4k = 2k 2015 Range Rover Autobiography 4.4 SDV8
Post #678097 16th Nov 2023 6:55pm
Rambles
Will go with Thinkware
Some great options for £200
Want a front & rear
And good enough quality for more than just proving non fault
Post #678210 18th Nov 2023 10:43am
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
I have used knock off go-pros in all my cars for years. They are extremely cheap, come with lots of fitting options have good resolution and wide angle lenses. Just ensure you set up the cycle record and for it to turn on and of with external power. I fit a cheap usb 12v inverter up in the roof consol area and run the usb cable to the top of the windscreen behind the rear view mirror where the go pro is fitted. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #678543 23rd Nov 2023 6:49am
DrRob
I use the Garmin Mini as its small and discrete and no screen. All set up via an app etc.
Very happy with it. Front only. Still working out how to mount one in the rear "properly" with no dangly wires Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #678546 23rd Nov 2023 8:29am
garyRR
You can clip it to the back of the headlining. If you gently lever it down, you can feed a cable through and down the rear pillar (these also pull off quite easily) into the rear fuse box and hey presto. 2015 Range Rover Autobiography 4.4 SDV8
Post #678548 23rd Nov 2023 9:00am
DrRob
It's the clip/mounting that I'm head scratching over for the Garmin Mini Laughing
https://www.garmin.com/en-GB/p/731428 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #678563 23rd Nov 2023 12:09pm
garyRR
Stick it to the window and mount it in the upper tailgate?
It's just 3 easily accessible bolts to remove the spoiler and the bung should be easily accessible to feed a cable through (the cables for the rear camera go through the same one). The top trim on the upper tailgate just pulls off - it has 2 clips into the side trims on either side.
Iirc there is a switched live in the upper tailgate, so you could just piggyback that and not need to feed any cable through. 2015 Range Rover Autobiography 4.4 SDV8
Post #678604 23rd Nov 2023 7:38pm
Kiss My Carbon Footprint
United Kingdom 2011 Range Rover Autobiography TDV8 Orkney Grey
Removing the L322 tailgate upper trim panel requires great care.
The fixings are thin plastic blades moulded into both the upper and lower edges of the panel.
They slide into metal "grips" which are a push fit into the tailgate body panel.
The plastic blades are quite thin and break with little encouragement.
From memory there are either six of eight of them - if you only break a couple you'll be doing well.
Break too many and you'll need a new panel.
If the panel has been off a number of times already, it may come away relatively easily.
But in that event some of the "blades" will quite likely be broken already.
New replacements are not cheap - assuming they're still available.
Second hand examples like all used interior trim panels often leave much to be desired.
Using a trim removal tool at the panel ends will very likely take some paint off both the panel you're attempting to remove and those adjacent.
The last time I needed mine removed I had my Indy do it - no damage at all.
He did it by gripping the panel at the upper and lower edges, pulling firmly (but carefully) away perpendicular to the panel, working his way along the panel a little at a time so as separate it evenly along its length.
The key here is to pull the panel away evenly both vertically and laterally, such that the plastic "blades" are not stressed.
If yours is still pristine then consider how confident you feel.
This may be a task to delegate to an expert.
Warwick 2011 L322 TDV8 A/b Orkney Grey
2008 Defender 90 XS TDCi Java Black
2002 L322 TD6 Vogue Zambezi Silver (gone but not forgotten)
And one or two bikes - Ok, maybe more than one or two....
Post #678614 24th Nov 2023 12:52am
Gremlin500
I got a couple of these almost 10 years ago, and both are still working well, great image quality, and loads of features, G-sensor, etc.
Car DVR Dash Camera Rear View Camera Video 1080P Full HD 2.7" Cycle Recording Night Vision G1WH Wide Angle Dash Cam https://a.aliexpress.com/_EynJ4HX “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #678620 24th Nov 2023 10:54am
JoolsB
United Kingdom 2012 Range Rover Vogue TDV8 Buckingham Blue
I’ve got one of these and switch it into whichever car I’m using, you can get moody fittings on the bay - it’s a 10mm ball if I recall.
I was thinking of getting a rear one and also pondering where to mount it, but it’ll probably go in the top of the screen so I can switch it onto the defender easily.
Post #679378 3rd Dec 2023 9:57pm
