![]() | Home > Technical (L322) > air suspension |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 764 ![]() ![]() ![]() |
ok RR 2005 4.4 petrol
the gap tool says
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35485 ![]() ![]() |
stick it in off road and test the air bags for leaks....
thanks for your reply
its flat this morning so i assume the bag is leaking
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 544 ![]() ![]() ![]() |
Sounds like an air bag to me I'm afraid. Drives:
yes, i think you are right, it dose look in good condition, i will see when i get it out.
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 331 ![]() ![]() |
Airbags often get leaks at this time of year as the weather gets cooler.
thanks for your post RR 2005 4.4 petrol
I left the car parked up four 4 days and the air bag was still up.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
Faulty/sticking valve block inside the wheel arch? 2015 Range Rover Autobiography 4.4 SDV8 |
garyRR
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 457 ![]() ![]() ![]() |
the valve block can be found behind the wheel liner on the front right wheel looks like this |
thanks RR 2005 4.4 petrol
