Home > Technical (L322) > air suspension |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 737 |
ok RR 2005 4.4 petrol
10th Nov 2023 1:47am |
the gap tool says
10th Nov 2023 9:43am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35281 |
stick it in off road and test the air bags for leaks....
10th Nov 2023 10:09am |
thanks for your reply
11th Nov 2023 11:52am |
its flat this morning so i assume the bag is leaking
12th Nov 2023 6:04am |
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 540 |
Sounds like an air bag to me I'm afraid. Drives:
12th Nov 2023 7:42am |
yes, i think you are right, it dose look in good condition, i will see when i get it out.
12th Nov 2023 11:41am |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 329 |
Airbags often get leaks at this time of year as the weather gets cooler.
13th Nov 2023 9:24pm |
thanks for your post RR 2005 4.4 petrol
14th Nov 2023 1:03am |
I left the car parked up four 4 days and the air bag was still up.
17th Nov 2023 2:48am |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1465 |
Faulty/sticking valve block inside the wheel arch? 2015 Range Rover Autobiography 4.4 SDV8 |
17th Nov 2023 11:45pm |
garyRR
18th Nov 2023 1:26am |
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 395 |
the valve block can be found behind the wheel liner on the front right wheel looks like this |
22nd Nov 2023 5:31pm |
thanks RR 2005 4.4 petrol
22nd Nov 2023 11:53pm |
