![]() | Home > Technical (L322) > Thumping underneath |
bradww Member Since: 24 May 2023 Location: Chesterfield Posts: 35 ![]() ![]() ![]() |
Diff? |
Shaunj69 Member Since: 25 Feb 2022 Location: Bristol Posts: 57 ![]() ![]() ![]() |
Hi bradww
Eastsoutheast Member Since: 10 Jan 2023 Location: Wimblington Posts: 169 ![]() ![]() ![]() |
If it was the transfer box would it do the same in low and high range? 2012 4.4 TDV8 Vogue Santorini black ivory leather |
Hi Eastsoutheast
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2663 ![]() ![]() |
The centre bearing itself doesn't seem to be the reason for changing the bearing, instead the rubber mount for the centre bearing deteriorates allowing the prop-shaft to flop about. Have another check of the rubber bushing around the bearing. |
Hi mate
willeywilson Member Since: 24 Feb 2022 Location: Staffordshire Posts: 4 ![]() ![]() ![]() |
Check all 4 tyres tread depth. When I bought mine some plonker had fitted winters on the rear with 11mm tread left and summers on the front with 4mm. This was causing the Transfer box to have a hard time of it whenever I was moving relatively slowly (less than 50mph) and giving it some throttle. Up hill and accelerating at ~30mph would result in a bang bang bang from the transfer case. Felt like driving over a cattle grid to some extent. Cruising down the motorway it wouldn't make the noise. 4 new tyres fitted and all was resolved. Thankfully no lasting damage to the transfer box as far as I can tell. |
Hi Willeywilson
MartinD Member Since: 20 Oct 2010 Location: Edinburgh Posts: 303 ![]() ![]() ![]() |
How did you get on with this Shaun? 2011 4.4 TDV8 Vogue SE - 'Black Betty'
Hi mate
