Home > Maintenance & Mods (L322) > Gutted broke down had to be recovered ..update..
Furnitureman
United Kingdom 2012 Range Rover Westminster 4.4 V8 Cairns Blue
Driving along nicely then noticed we were slowing gradually no response from throttle, then restricted performance and gradually ground to a holt, engine sounded like it wasn’t running on all 8, no smoke not really noisy but no response from throttle, on a long pitch black road luckily a copper pulled up behind and put blues on, I could start engine to get in in neutral to get it on tow truck engine running really rough again no response from throttle then it would die, no idea what’s gone wrong 2012 Range Rover Westminster 4.4 TDV8
2006 Discovery 3 HSE 260k miles and still going strong with a new owner
Post #677288 4th Nov 2023 11:20pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
blocked dpf, low pressure fuel lift pump? BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #677290 5th Nov 2023 1:29am
Vogue
Sounds like fuel starvation - when was the filter last changed, or perhaps contaminated with water. I also had similar symptoms with a new RR Classic in 1987. It was a rubber fuel tank seal that had dropped into the tank on assembly and had been sucked up by the fuel intake pipe blocking off the fuel supply. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #677293 5th Nov 2023 6:27am
Furnitureman
No warning on DPF could be fuel pump 2012 Range Rover Westminster 4.4 TDV8
Post #677297 5th Nov 2023 8:02am
Furnitureman
New LR filter fitted Tuesday done about 200 miles, not been through any standing water and only use V power it’s parked up at my mechanics so I’ll hopefully find out Monday 2012 Range Rover Westminster 4.4 TDV8
Post #677298 5th Nov 2023 8:03am
Arch Stanton
England 2018 Range Rover Autobiography SDV8 Corris Grey
I'd be checking the new filter, is it possible to fit it incorrectly and it foul/get sucked into the system enough to bllock? First time FFRR owner
Post #677299 5th Nov 2023 8:36am
Furnitureman
Garage had a look today it’s thrown the timing chain on the lhs as you look at the engine 😡😡 took a look through tje oil cap hole and it’s lying to one side, next question is it an interference engine is it fubar 2012 Range Rover Westminster 4.4 TDV8
Post #677923 14th Nov 2023 10:04am
kevinp
https://fb.watch/oj1g3bTfvS/
Does this look promising?
Post #677925 14th Nov 2023 10:28am
Furnitureman
that does give me hope thanks for posting that 2012 Range Rover Westminster 4.4 TDV8
Post #677927 14th Nov 2023 10:37am
dhallworth
Yikes, that’s really, really rare on a 4.4 TDV8. A seriously bad bit of luck!
How many miles had the car done? 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #677967 14th Nov 2023 8:19pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
My 5.0 v8 Supercharged L405 had an engine rebuild after it slipped a cog on timing chain, it now runs better than ever in fact just like its rolled out of factory. If you need a good garage as a recommendation then happy to provide details, only trouble is that its in Essex but very worth travelling for. let me know if you need details. Good luck and hope it's not too bad.
Post #677968 14th Nov 2023 9:15pm
Furnitureman
Hi Drf can you send details please ive got a few leads one is by the garage who did the video earlier in the thread £4500 to collect, replace timing chains etc, an extra £700 per cam shaft if there damaged so potentially £6800 or range rover engine specialists in Essex (could be the one you used) a full reconditioned engine £7500.00 but only 6 months warranty 2012 Range Rover Westminster 4.4 TDV8
Post #678156 17th Nov 2023 3:28pm
pcourtney
Also contact my guys in Barking ( South East Essex ) Tel 020 3542 0100
https://4x4enginerebuilds.co.uk/
Post #678158 17th Nov 2023 4:16pm
Wifeys has just gone pop! Ive chosen to buy a damaged car and remove the engine! Worried me going down the rebuild route, as JLR don't sell any engine parts!
Post #678184 17th Nov 2023 10:38pm
Furnitureman
That’s a worry I’d do the cam belts myself it’s the getting the engine out etc now I’m in a dilemma bloody cars 2012 Range Rover Westminster 4.4 TDV8
Post #678226 18th Nov 2023 1:11pm
