Home > Technical (L322) > Can one of you geniuses design me a way to bung this tube?
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
I need a new radiator drain plug, but none are listed for the 4.2 supercharged.
My plug is in the rad, but coolant still comes out of the drain pipe. I shouldn't have had the audacity to use a drain plug to drain the coolant Rolling Eyes
So I need to bung the drain pipe "stub", which is the tube that the hose is attached to in the picture below. I was that mad that I thought about shoving a cork in it Rolling with laughter
The pipe itself is about 10mm long with no thread on it or in it, so I need one of you geniuses to think of how I can block it to stop any coolant coming out!
Cheers
Post #677094 2nd Nov 2023 6:22pm
Phoenix
Have you taken the 'tap' out and checked for a damaged 'O' ring or debris in the valve?
If you do choose to block it up, it'll need to hold ~1.5bar pressure...
Post #677095 2nd Nov 2023 6:47pm
philip1972
Thanks.
I did take the red tap out and one O ring fell off. So I put a new one on and it’s holding the coolant now, but I wanted belts and braces to be honest.
Post #677101 2nd Nov 2023 7:24pm
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Exactly the same thing happened to me as well. I had to remove one of the bottom pipes to drain the system though as it was way too slow via the tap.
I too have changed the O rings but I still have a drip when the system is under pressure. Solving it is on hold at the moment but I will get round to it sometime.
I could not find a new tap insert for a supercharged but I bought one LCM000010 that looks identical but I have not tried it yet.
https://parts.jaguarlandroverclassic.com/l...drain.html have them listed for RR 2002 to 2009
I bought mine from British Parts UK for less than £2.50
David Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #677123 2nd Nov 2023 11:10pm
