Home > Technical (L322) > Nobody knows what is going on with my 4.4 TDV8 2011...
Page 3 of 3 <123
JayGee
Yorch1 wrote:
cass wrote:
What problems were you trying to fix when you had the remap/EGR removal?
Many will disagree but I would always undo any improvements/mods before trying to find a fault, you could be chasing your tail forever without a solid place to start.
Well...I had an EGR problem with restricted performance. I decided to blank it to save some money but so far I have spent much much more. I really regret it.
I assume you had the EGR function mapped out in the ECU as well as physically blanking it? A broken throttle plate function would cause a EGR fault, as I said earlier, as it's used to regulate EGR flow. 2012 TDV8 Vogue (L322)
Post #676999 1st Nov 2023 1:14pm
DrRob
I'd be putting all back to standard if I were you....I reckon it's been bodged Whistle Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #677010 1st Nov 2023 2:51pm
Yorch1
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Java Black
Yes Laughing
Post #677026 1st Nov 2023 5:52pm
Phoenix
rjff wrote:
Here you go Phoenix
From mine:
Butterfly become well fouled and finally sheared the drive gears.
Thanks, two different failure modes with two different causes though, yours appears to have eaten itself trying (and failing) to reach a commanded position due to excessive friction on the spindle in it's bushings or carbon build-up.
The one I posted a photo of moved freely but kept changing position due to the measured position not conforming to the commanded position, the cause was the oil ingress past the spindle seal contaminating the electrical component connections - the symptoms are similar to to those mentioned above, hence the reason for posting.
Post #677033 1st Nov 2023 7:01pm
Page 3 of 3 <123
