![]() | Home > Technical (L405) > L405 V8: Crankcase Fumes in Cabin |
Stuart- Member Since: 16 Dec 2017 Location: UK and Hong Kong Posts: 338 ![]() ![]() ![]() |
I have an intermittent problem with my L405. There is a smell of what seems like crankcase fumes in the cabin sometimes.
More like the oil cooler I think, many thanks. I'll get it fixed under warranty at the stealer. 2017 4.4 SDV8 Autobiography in black
I thought I'd follow up on this.
knwatkins was spot on. Oil cooler leaks into the V, and when you give it the beans, the oil blows back onto the exhaust causing the smell. Being fixed by Sytner as we speak under warranty along with a few other things. I'm glad I bought the warranty now with the car. 2017 4.4 SDV8 Autobiography in black 2018 D300 SE Velar in champagne 1982 Rolls Royce Silver Spirit in green Spiffing wheel centre caps, L322 sill repair panels, etc |
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 299 ![]() ![]() ![]() |
I had and still have this intermittent issue I had the oil cooler replaced along with the rings at the back of the cooler which can cause a small drip also. I had no issues for a few months then suddenly that dreadful smell again with the visible smoke at the back of the engine bay. The strange thing is may be a coincidence but I'm sure the car was doing a DPF regen when smell and smoke appeared again. This issue is turning out to be pain the ass to diagnose now and one of the many issues with this model L405! Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
Have you had the oil feed hoses at the back top of the engine inspected? They can drip oil onto the exhaust and bell housing, which will create some nasty smells that get sucked into the cabin.
Hi Gary yes had the hoses checked and o rings changed also on the feed hoses. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
