Home > Maintenance & Mods (L322) > Trickle Charge
Garymahoo
Trickle Charge
Hi all,
Is anyone using a quick release trickle charger set up? (Like an optimiser for motorbikes).
Due to work my car can be parked up for 3-4 weeks at a time in the drive and i wamt it to start when i come home
I have an outside weatherproof socket at the front door so power shouldnt be an issue.
Cheers
Post #676984 1st Nov 2023 10:59am
Gremlin500
Hi, I have a CTEK MXS-5 in my garage on the wall, connected to a quick-release socket mounted in the front grille. CTEK do a range of QR accessories to make it simple to set this up. I fished the cable through using duct tape and bicycle outer gear cable, took 2mins:
 “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #676987 1st Nov 2023 11:24am
Gremlin500
Better to have the charger indoors, -safer and more secure.
The 12V is better than mains voltage in the rain etc.
CTEK do 12V extension leads also. Not cheap, but you get what you pay for.
A little silicone grease in the socket helps keep the water out. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #676988 1st Nov 2023 11:27am
Garymahoo
Thanks for the replies
I was considering hiding the charger in the engine bay area while im away so all is locked up. The quick release would just be for simple use with less chance of a crocodile clip maybe jumping off.
Im maybe daft but unsure whats meant with a 12v extension cable?
Definately food for thought.
Cheers
Post #676994 1st Nov 2023 12:42pm
Gremlin500
See here under “Accessories”
https://www.ctek.com/uk/battery-chargers-1...mxs-5-0-uk
You mount the charger indoors, and run the 12V cable to the vehicle.
Advantage is, if you forget and drive off, it just unplugs itself & no harm done!
(Ask me how I know….. Whistle Embarassed )
Having the charger unit inside the engine compartment won’t exactly prolong its life, and what happens if it malfunctions and toasts your lovely FFRR? There’s always a risk however small, but if its not there, the risk is zero. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #676995 1st Nov 2023 12:58pm
Baltic Blue
Just a long section of cable with a 12v plug and socket.
Post #676996 1st Nov 2023 1:00pm
Gremlin500
@BB: Good man! Thumbs Up
My grille socket is just held in by two small cable ties, it seems to work well enough, cables go directly on to the +/- posts under the bonnet, so it all looks very neat, and easily removed. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #676998 1st Nov 2023 1:09pm
I wonder how long until some one comes up with electromagnetic induction to keep a car battery topped up, just drive onto an inductive coupling and away you go.... Question Pete
Post #677000 1st Nov 2023 1:14pm
Baltic Blue
That should cook your chips well Rolling with laughter
Stick to the spanner’s Pete. Rolling with laughter
Mike. (Sorry, bored because of the rain Big Cry ) G reg 2.5VM Vogue Portofino red 1991- 1999
Post #677001 1st Nov 2023 1:23pm
If they can do it for EV's then why not...??
https://evchargingsummit.com/blog/everythi...-charging/ Pete
Post #677003 1st Nov 2023 1:46pm
Gremlin500
Tut, tut, ever so slightly OT, both! Twisted Evil Laughing Whistle “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #677005 1st Nov 2023 1:55pm
Garymahoo
Ahh. Excuse the brain fart.
I like that.
Another one to add along with my Ali express screen for Android auto.
Im supposed to be selling this thing but i dont see it happening if i keep buying accesories to make it even better haha
Post #677007 1st Nov 2023 2:04pm
Gremlin500
@Gary:
Perhaps you should check out the “Drunken Purchases” thread on here, good for a few laughs, or worse still it might give you a few ideas………. Rolling with laughter Rolling with laughter Rolling with laughter Whistle “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #677014 1st Nov 2023 3:44pm
Garymahoo
@gremlin. Oh dear.
I just had a look.
Oh dear haha
Post #677015 1st Nov 2023 3:52pm
