![]() | Home > Maintenance & Mods (L322) > over 2L of fluid from front diff |
What colour was the oil?
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
They probably took out the filling plug, then got distracted, came back to it and filled it up without draining the original oil ?
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2575 ![]() ![]() ![]() |
The diff probably appreciated decent lubrication. |
The fill plug is also the level plug IIRC |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
They have probably adopted the level fill method to the plug (i havent tried to see how much it will actually hold). This isn't correct and instead the diffs take specified quantities.
From the L322 pages on Topix
Phoenix, I reckon the vehicle may have been jacked up. 2015 Range Rover Autobiography 4.4 SDV8 |
I was wondering if it'd drawn any water in (hence asking about the colour), used to get that on the old Defenders if the breathers had been blocked or re-routed to create a 'U' bend, which would effectively block the breather, causing a hot diff suddenly quenched by cold water, to draw in water past the seals... |
BLRover Member Since: 15 Oct 2023 Location: Tennessee Posts: 17 ![]() ![]() |
Appreciate the input!
